Page 1 of 6 1 2 3 4 5 6 LastLast
Results 1 to 15 of 88
    Oct 2021
    Ontario Canada
    Hydrostream voodoo rebuild/restoration
ID:	498910Hi I’m 18yrs old I’m located I’m Minden hills. Ontario.. I bought this voodoo 3yrs ago and noticed there was wood chunks floating in the water coming out the drain plug. So I decided I’m gonna rip the floor out.. then I ripped the floor out and just decided that the boat needed a ton of work so I decided that all do a full rebuild so follow along!!!
    full videos and pictures will be posted on Instagram and YouTube @Zammit_Racing
    thanks for watching!
    youtube: https://youtube.com/channel/UCGy7j7CoScBfMiWNNYzgruA
    instagram: http://instagram.com/zammit_racing/
  2. Thanks mattmak77 thanked for this post
    Likes SCT, LakeFever, 89LASER, tnelsmn, mattmak77 liked this post
    Jun 2018
    Floating around
    Voodoos are cool little hulls. It’s a lot of work to restore but a lot of fun. I watched a couple of your vids, looks like you can use a finned roller. Bubbles can be drilled and injected with catalyzed resin using a syringe. Hope this is of some help
    Oct 2021
    Ontario Canada
    Hey buddy thanks for watching! I bought a roller for air bubbles now. but yes I will grind all air bubbles down I’m not to happy with them there.
    appreciate the advice since it’s all new to me so it’s all helpful!
    Oct 2021
    Ontario Canada
    So the story of this boat is a hole formed near the back of the pad so the back half of the boat (pad,core,floor,transom pice added) was done about 3yrs ago right before I bought it but everything was factory. It needed to be rebuild years ago can’t believe it was still holding up my 300+lbs Mercury 75hp on a 4”setback?
    Before I started I was just gonna replace the floor but as I cut my way into the boat I realized that its gonna need everything replaced so it got real from there. So I got planning to split the top half off so I could get at everything since it’s so small, I invested in advanced Composite materials so I can make it as light as possible so I can go fast!!!
    enjoy the build it will a very special voodoo when it’s all built up!
    youtube link: https://youtu.be/zFfKKjHTh3E
ID:	498914Click image for larger version.
ID:	498917Click image for larger version.
ID:	498916Click image for larger version.
ID:	498918Click image for larger version.
    Attached Thumbnails Attached Thumbnails A8013B13-3EE4-408C-B53C-2C9BCF5D5CC6.jpg
  6. Likes 89LASER, tnelsmn liked this post
    Jun 2018
    Floating around
    It gets a lot easier quickly. What we did the first 40hours of lays we could do now in 4 and it would look as good or better. There’s two of us working together and I lay out the sheets and flatten them down by hand best I can while the other preps resin and wets out the sheets while I fin roll. I had a bit of a surprising revelation along the way because I kept trying to roll the bubbles out, and now I try and lay the glass flat. What that means is often my air bubbles which I had to work very hard at first to remove were not “under the glass needing removed” but rather the glass was stretched out a bit too much and needed to be pushed into the corners and transitions. This means I now mostly roll using the finned roller in towards the corners and transitions to help the glass lay down tight. Then after it’s in there right I roll the rest of the bubbles out of the end of the glass mat. Gotta watch you don’t pull the mat back out of the corners though and make a new air pocket.
    keep up the good work, I’ll follow along best I can.
  8. Likes rgsauger liked this post
    Oct 2021
    Ontario Canada
    Thanks for that. My dad is helping me along the way with the mixing and layout part since it’s hard to do by myself but yea it’s kinda been just me working on it till now because the “rebuild” part of the build I want it to be as perfect as I can get it. I like to take my time and do the best I can just the way I am! Didn’t know a thing about fiberglass till I started this build. But after I closely inspected the core job I did I know exactly what I need to improve on and did a way better job on laminating the transom very happy with that!
    new video soon!
    just saw your build pics beautiful work! Looks awesome
  10. Likes LakeFever, rgsauger liked this post
  11. #7
    Jul 2011
    Peterborough, On
    Looks good! Want to race It? There's a few classes it'll fit in here in Ontario
    1989 Canadian Edition Vision Sold
    1990 Hydrostream Virage Stage 3 Turbo
  12. #8
    Oct 2021
    Ontario Canada
    Hey man! yea I can consider racing it sounds fun! I was just planning on building a lightweight boat to scream down the lakes
    here’s a link to my Instagram to get a better conversation going if interested to anyone out there that’s wants to talk boats!
  13. #9
    Jul 2011
    Peterborough, On
    Quote Originally Posted by Zammit_Racing View Post
    Awesome! Check us out at http://opbra.ca/ class info is all there.
    Oct 2021
    Ontario Canada
    Quote Originally Posted by idvette View Post
    I will look into that for sure thanks buddy! Sounds like a blast would love to get my boat together with the big boys!
    Oct 2021
    Ontario Canada
    I cut out the floor and grinded as much carpet glue and excess glass and resin as I could before I split the boat.
    the carpet glue was melting from the grinded and was slinging hot wet glue all over me was not fun got burnt a couple times. Also ripped out the float boxes witch were wet and heavy.
ID:	498931Click image for larger version.
ID:	498932Click image for larger version.
ID:	498933Click image for larger version.
ID:	498934Click image for larger version.
ID:	498936Click image for larger version.
ID:	498937Click image for larger version.
  16. Likes 89LASER, mattmak77, Tucker1968 liked this post
    Oct 2021
    Ontario Canada
    Time to pull the motor off.. So I built a stand outta scrap wood, I didn’t have the proper hook to thread in to the flywheel to hoist the motor off so I had a pice of steel plate bent at 90° and drilled 2 holes and threaded in 2 smaller bolts in the flywheel it had smaller threads around the big center thread that’s probably not good the lift 300+lbs on that but that’s all I could whip up at the time and drilled a hole on the vertical side of the steel so I can hook it up to a chain.
    I have bought the proper lifting hook now so I fell a bit better about re rigging!
    Video: https://youtu.be/9GWT1lFgGpc
ID:	498982Click image for larger version.
ID:	498985Click image for larger version.
ID:	498986Click image for larger version.
ID:	498987Click image for larger version.
ID:	498988Click image for larger version.
ID:	498989Click image for larger version.
ID:	498990Click image for larger version.
ID:	498991Click image for larger version.
  18. Likes Ing, 89LASER, tnelsmn liked this post
  19. #13
    Oct 2021
    Ontario Canada
    I flipped the boat over so I can build a frame to sit the hull in so I can split the top half off. So I started to profile the the bottom hull onto 1/2” plywood, About a couple hundred cuts later I had all my pieces cut and ready to start building was very happy with the way it turned out! Boat fits in perfectly real tight fit.
    I put 2 2x4s along the bottom and rested the frame on 4 snowmobile dollies so I can roll it out side to cut and grind so I don’t coat the garage in fiberglass dust…
    video: https://youtu.be/B7Smqoek2Ms
ID:	499060Click image for larger version.
ID:	499061Click image for larger version.
ID:	499062Click image for larger version.
ID:	499063Click image for larger version.
ID:	499064Click image for larger version.
ID:	499065Click image for larger version.
ID:	499066Click image for larger version.
ID:	499067Click image for larger version.
  20. Likes 89LASER, idvette, doug7488, tnelsmn liked this post
  21. #14
    Oct 2021
    Ontario Canada
    Time to split the hull! I took a Milwaukee multitool and went around the hole boat, There was no seam to base my cut on and there’s not much to base it on so I split the difference and cut away took about 9hr to cut went threw about 5+batteries! Fortunately it worked out perfectly I cut it in the right spot and I got a nice surface around the whole lip so that’s a relief because I was worried I wouldn’t be able to do it…
    Video: https://youtu.be/GhO2Pt79Z_I
ID:	499092Click image for larger version.
ID:	499093Click image for larger version.
ID:	499094Click image for larger version.
ID:	499095Click image for larger version.
ID:	499096Click image for larger version.
ID:	499097Click image for larger version.
ID:	499098Click image for larger version.
ID:	499099Click image for larger version.
  22. Likes tnelsmn liked this post
  23. #15
    Oct 2021
    Ontario Canada
    Time to rip out the transom!!!
    the transom is original form factory.. The bottom half under the splash-well there was a piece of 1/2” ply wood added then glassed in by a fiberglass guy before I bought it, Im guessing that was added because the wood was so soft the bolts had nothing to back onto. Makes sense because the wood is so soft/rotten!
    Not sure how it was still holding up my 75merc that weight just over 300lbs witch is sitting on a 4”setback
    and the boat is only rated for a 50hp maximum
    transom literally fell out as seen below!
    video:https://youtu.be/Fwtu_EyyV2A
ID:	499156Click image for larger version.
ID:	499157Click image for larger version.
ID:	499162Click image for larger version.
ID:	499159Click image for larger version.
ID:	499164Click image for larger version.
    Attached Thumbnails Attached Thumbnails 55E71AAD-2807-4728-9DF2-00BEB260A078.jpg
  24. Likes tnelsmn liked this post
  1. Hydrostream VooDoo
    By Coonass2020 in forum Hulls Wanted
    Last Post: 08-31-2021, 03:55 PM
  2. One of a kind Hydrostream Voodoo?
    By shane65 in forum Ebay Listings and Other Internet Listings
    Last Post: 05-20-2021, 08:19 AM
  3. 13' Hydrostream VooDoo
    By 89LASER in forum Ebay Listings and Other Internet Listings
    Last Post: 04-29-2020, 01:44 PM
  4. Hydrostream Voodoo
    By Voodoo in forum Technical Discussion
    Last Post: 04-19-2010, 07:15 PM
