Page 3 of 3 FirstFirst 1 2 3
Results 31 to 32 of 32
  1. #31
    Jun 2021
    Australia
    Yes I'll definitely inspect reeds when doing the carbs. Waiting for the carb kits to arrive. Yes the rings had tension and rebound. I could see the top ring sliding smoving sideways back and forth as piston went up and down. As I understand it this sideways play increases as rings wear but I'm assuming some is normal. My factory manual says to check the side clearance of rings with a feeler gauge and refers to the specifications page for measurements but the specs only mention acceptable width range of upper and lower rings, not clearance of ring groove. I have feeler gauges but no way of accurately measuring the width that accurately. It says 0.0895 - 0.0900in for upper ring. If I get the rest of the engine sorted without any nasty surprises and get some use out of it I'm happy to factor in a rebuild down the track. Time is a problem with 3 young kids.
  2. #32
    With halfway through a set of gaskets, it's a bugger to put it together again without the whole deal.
    Hopefully your head gaskets don't fail next hahaha.
    Better use 39:1 and hope it's not too slippery and it chucks a ring. I hear you 3 kids, give them paddles.
    Just pulling your leg.
  1. Sea star pro cylinder on 1975 merc 150 6 cylinder inline
    By scott reierson in forum Technical Discussion
    Last Post: 10-02-2018, 09:55 AM
  2. Sea star pro cylinder on 1975 merc 150 6 cylinder inline
    Last Post: 07-17-2018, 11:08 AM
  3. 1979 Johnson 55hp 2 cylinder Good Compression
    By baja030 in forum Outboard Engines
    Last Post: 09-22-2017, 04:21 PM
  4. OMC Tech: '79 Johnson 115 low compression on one cylinder
    By JoshKeller in forum Technical Discussion
    Last Post: 05-30-2012, 09:05 PM
