Results 1 to 8 of 8
Thread: WH carbs.
12-18-2021, 10:49 PM #15000 RPM
- Nov 2021
- Holland,Michigan
- 111
- 18
WH carbs.
Looking for a set of WH22 or WH31 carbs.
12-19-2021, 09:54 AM #2
Contact ShadowFlier here on the site. I think he has a pretty good inventory and might be the guy you need. Good luck.
RockTeam Junk
SJD1974 thanked for this post
12-19-2021, 10:12 AM #35000 RPM
- Nov 2021
- Holland,Michigan
- 111
- 18
Thanks. Will do, ShadowFlier is in my area.
12-19-2021, 01:43 PM #4
I have s set of 22's
needs linkage and jets.
$100 shippedXR2001 & XB2002
12-24-2021, 06:32 AM #55000 RPM
- Aug 2019
- Palmharbor
- 557
- 20
- 58
- 150
I have several untouched dusty with linkage one connected to 7 petal intake with reeds
12-24-2021, 02:12 PM #65000 RPM
- Nov 2021
- Holland,Michigan
- 111
- 18
I will be getting back to somebody this summer about a set of something, i have other issues with it before i go doing mods. If what i here correct i will definitely be changing to some 22's or 31's.
Thank you all.1988 Bass Tracker 1800FS Tournament W/ Mercury 150 BlackMax 2.0
With a need for speed!!
01-20-2022, 05:37 PM #7Member
- Apr 2021
- Californian
- 55
I have a set of complete carbs if your still looking.
01-20-2022, 07:55 PM #85000 RPM
- Nov 2021
- Holland,Michigan
- 111
- 18
Not at the moment, thanks for checking in.
Can N70B carbs fit my M50D2 50hp carbs
By 25MegaToHoTsU in forum General Boating DiscussionReplies: 0Last Post: 04-12-2021, 12:38 PM -
200 WHM 1A carbs on a 1990 merc XR4 that had WMH 1A pumper carbs
By BASSCASTER in forum Technical DiscussionReplies: 15Last Post: 07-07-2014, 11:26 AM -
OMC Tech: Older 75hp evinrude carbs vs 86' 70hp johnson carbs
By roycesrolls in forum Technical DiscussionReplies: 2Last Post: 06-01-2012, 08:24 PM
