Results 1 to 15 of 17
Thread: Foot and hand throttle???
12-17-2021, 05:34 PM #1
Seems I remember ... Maybe Land and Sea made one?
Working on my XTB 21 and was toying with the idea of having both. It would be nice to be able to lock the throttle at 55 mph or slower.
Only way I can see it really working is to run the control box cable around to the back of the foot throttle with a stop on it.
Dave Strong, NICE PAIR liked this post
12-17-2021, 05:46 PM #2Team Member
- Lake Coochiching, Ontario
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
Land and Sea made one and I bought it. The hand throttle was difficult to use to adjust speed but could easily be used to maintain a constant speed. At least that’s how mine was
Forkin' Crazy liked this post
12-17-2021, 06:35 PM #3
I fooled around making a cable junction block (plastic sliding block in rect aluminum tube) that would left either control work independently but never finished it.
12-17-2021, 09:39 PM #45000 RPM
- Apr 2018
- Lake Placid, FL
- 155
- 18
- 33
- 107
12-17-2021, 09:48 PM #5
I was going to do this as well. Seems the L&S deal has some safety concerns that shyd my away from that option. Tnels has some European deal that looked really nice. Not sure what came of it.
im going to run two cables and switch them around at the motor when I want one or the other. Can’t see any other easy and safe way to go about thisHydrostream dreamin
12-18-2021, 10:12 AM #6Junior Member
- Oct 2021
- Orlando, FL
- 10
What about a Cable box for both cables to go to and a lock out for the foot pedal when you dont want to allow it to operate. Or a cable box that you can swap between foot and hand cables but mount it close to the foot and hand control. Would allow one cable to run to the engine, two shorter cables at the controls. Looking for a plant to do this to the 24 super I recently picked up.
12-18-2021, 10:13 AM #7
DTS makes it easy so long as you use the top mount hand control. They don’t make a harness that works with zero effort and foot throttle.
I have a mechanical 250 ProXS (too cheap to retrofit DTS when I repowered) and I used this to terminate the cables from the livorsi hand control and a SeaStar Pro foot control (1000 time better than the hot foot) then fed a single throttle cable to the motor. Works very well as long as you use the best, low friction cables.
https://www.hardin-marine.com/p-9275...solutions.aspx
Mark
12-18-2021, 10:28 AM #86000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 341
- 174
There was another thread on this topic and FlaBum (RIP) mentioned those dual-station kits as a good solution. If I can find it I'll post a link.
Matt
12-18-2021, 12:31 PM #9
Paul I have one in the BAJA, Land&Sea wanted you to use the good 33c cables to reduce friction and have no tight bends. The hand throttle is stiff even with the good cables, but the "Cruise Control" feature is nice. I always use the foot throttle unless cruising at one speed or water skiing. They come up for sale used at times, I have the install instructions if you find one.
Forkin' Crazy, David - WI liked this post
12-22-2021, 01:53 PM #10Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Go to the Nitra boats web site and look around. They have a dual Foot/Hand throttle they may offer to the US.
12-22-2021, 02:31 PM #11
Baicor design and machine can prob make u whatever u want ….. I think his name was rowboat on here ?
2003 mirage ski racer with e-tec power
12-22-2021, 02:43 PM #12
12-22-2021, 05:02 PM #13
Whatta ya think about one of those black knob, push button, pull to desired setting thingies?
https://www.amazon.com/Venier-Adjust.../dp/B06XD7N79CWriggleys gum makes me think of boating, "Double your engines, Double your fun"
12-22-2021, 06:59 PM #14Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
12-22-2021, 08:37 PM #15Team Member
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
Are the new 4 strokes throttle by wire? It would seem to make dual controls easier. Just curious as I have no plans for a 4 stroke and would be surprised if Mr Crazy had a 4 stroke.
L&S foot throttle with hand control
By 79cvx20 in forum Technical DiscussionReplies: 3Last Post: 05-02-2014, 11:47 AM -
Anyone run two cables so they could switch from foot to hand throttle?
By Ron V in forum Technical DiscussionReplies: 9Last Post: 08-14-2012, 09:38 PM -
hand/foot throttle
By donmac in forum Technical DiscussionReplies: 10Last Post: 06-19-2010, 02:20 PM
