Results 1 to 15 of 27
    Nov 2021
    N. Idaho
    Laser LTV setup and speeds
    Hull: 84 laser ltv production ski. 12v bowmount troller. Full floor. Deck over 30 gal tank 1 group 24 battery.
    Engine: 97 supermag 150, 1.87 gears, Bob's cone on 6" plate. 2 1/4" above pad. All props run low 6000 rpms.
    Might have a few more mph if rung out hard. GPS speeds.
    14 3/4"×28" signature 4 blade cleaver 77 mph.
    14 1/2"×28" dah worked big ear chopper 75 mph.
    14 1/2"×26" stock big ear chopper low 70s.
    14 1/2"×26" Yamaha drag 3 lower 70s.
    Edit: have since run 80.7 with the 4 blade cleaver.
  2. Likes Polaris6 liked this post
    Nov 2021
    N. Idaho
    20 roll
Name:	Screenshot_20211203-033046_Video Player.jpg
  4. Likes rgsauger liked this post
  5. #3
    Nov 2021
    N. Idaho
    Homemade interior, foot throttle, foot operated trim, and shifter.
ID:	498056Click image for larger version.
ID:	498057Click image for larger version.
  6. Likes Polaris6 liked this post
  7. #4
    Mar 2015
    DFW
    they run best (in my experience) with the engine mounted on the transom. that is with LTV closed deck models tho, the bass boat might like a little setback with the added weight. your speeds seem pretty reasonable given the HP of the engine you're running.
    STV Pro Comp Ski| 200 Merc
  8. Likes OnPad liked this post
  9. #5
    Nov 2021
    N. Idaho
    I have always heard that. I don't know how I would pull that off, without a 15" mid. Upper bolts are 2" above my transom.
    My boat is probably a little heavier with troller mounted to the bow. I also replaced the transom and knees. 2" transom plus 1/2 aluminum (extra weight). One piece knees ( little more weight). Were not going to talk about my belly.
    Doesn't seem to like to lift till about 60.
    I just measured my plate I guess it's only 6".
    It was nice of you to say reasonable versus Slow.
  10. #6
    Houston, TX
    My shadow has a very similar bottom to your laser. Mine gets up on the pad and really wants to roll around 63 or 64 mph. Sounds about the same as yours.
  11. Likes OnPad liked this post
  12. #7
    Nov 2021
    N. Idaho
    Shadow made a nice looking boat.
    Pretty quick from what I've read.
  13. #8
    Houston, TX
    Yeah, if you have the skill and the balls, they will haul the mail.! I am still learning how to drive mine on pad so I’m taking it easy going for the top and number. Should max out around 82 or so. 200 motor. I have a picture of a buddy of mine‘s GPS speedometer in his shadow at 106 with a Bridgeport on back. That was tournament load! Lol
  14. Likes OnPad liked this post
  15. #9
    Nov 2021
    N. Idaho
    Update: Made 78mph last night.
    Maybe if I lost 20 lbs, and got rid of the troller, I could get 80.
ID:	510817Click image for larger version.
ID:	510818Click image for larger version.
  16. Likes rgsauger liked this post
  17. #10
    Houston, TX
    Sweet boat!
  18. Thanks OnPad thanked for this post
  19. #11
    Jun 2009
    Britsh Columbia
    We had a STV Kevlar Version with a 2.4 Bridgeport and then a 2.5 260 / with MOD VP gear case 20”
    mounted on CMC jack plate. 26 pitch Mazco RE chopper - would run 90-92 mph Saftey without lifting the nose. sure cornered hard. The boat could go faster but above mid 90s they were notorious for blowing over
    ON VACATION
  20. Likes OnPad liked this post
  21. #12
    Nov 2021
    N. Idaho
    Nice! Always good to hear another Laser/STV story.
    I wonder if you could have bested the century mark with a cleaver, or drag prop? My boat runs way flatter with a cleaver vs. round ear. Although, if your anything like me, I don't want to be in a boat wreck.
    I took Laser Ed's advice and bought a four blade cleaver. If I remember right, he ran his nearly 120mph.
    Not that I'm anywhere near his speeds. I had the same problem he did with excessive slip using 3 blade props, trying for top end numbers.
    I do like a 28p chopper, if I have a passenger.
    Also have a 28p mazco, and 28p Signature E.T. in 3 and 4 blade, that I haven't tried yet.
  22. Likes laser_ED liked this post
  23. #13
    Aug 2015
    Southeast
    Quote Originally Posted by OnPad View Post
    So I have to ask, are you fishing out if it? What's rhe deal with a trolling motor mounted on the deck?
    STV ProComp w/ 225 Promax
    STV Procomp with 280
    25 Liberator "The Battleship"
    Blazer 650 Pro Tour
  24. #14
    Nov 2021
    N. Idaho
    Quote Originally Posted by DangerNewb View Post
    Yeah, alot before I bought a Champion, and then a Bullet. Still fish out of it when I take it out. I have to watch where I stand on the deck, a little thin above the deck reinforcement channels.
    It was kind of gnarly to run a drill into the deck, in order to mount a 10 cent troller.
  25. Likes rgsauger liked this post
  26. #15
    Nov 2021
    N. Idaho
ID:	513471Click image for larger version.
ID:	513472Click image for larger version.
ID:	513473Click image for larger version.
ID:	513474Click image for larger version.
  27. Likes rgsauger liked this post
  1. Laser LTV Bass boat with 200 merc speeds?
    By mjpowersports in forum General Boating Discussion
    Last Post: 03-15-2015, 08:00 PM
  2. 16 superboat CC with v6 merc? speeds, setup and pics?
    By syclone01 in forum General Boating Discussion
    Last Post: 09-01-2011, 06:19 AM
  3. laser setup
    By 99 Sierra in forum Props, Setup, and Rigging
    Last Post: 03-02-2009, 09:32 PM
