Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
    Mar 2016
    cincinnati, ohio
    Really stupid question... are you spraying the paint or rolling??? How are you applying it???
  4. #19
    Jul 2009
    Maine
    Quote Originally Posted by 1954bmw View Post
    Exterior was sprayed. The interior will be rolled.
    Rich E.
    17' Action Marine/2.5 Pro Max 200
    "Badges.........We don't need no stinkin' badges........"
  5. #20
    Jul 2009
    Maine
    I making slow progress. Seat boxes and knees reglassed. Toe board, Hot Foot, and shifter mounted, along with the interior being painted.
    I’ve got 1/8” carbon fiber that I’m using as an overlay for the dash. I’m trying to figure out what I should use to bond it. I don’t want to rely on the gauges alone holding it in place. Any suggestions?
ID:	513365 Click image for larger version.
    Rich E.
  6. #21
    Jun 2018
    Floating around
    Bonding over paint? I'm thinking 5200 and leave it clamped for at least 12 days to cure. No more nails or PL might also work well. Gorilla glue too. Lots of options. If going over gel it would probably bond excellent with vinyester resin if you key both surfaces
  7. Thanks Old_Skool thanked for this post
    Likes Old_Skool liked this post
  8. #22
    Jul 2009
    Maine
    Actually, it’s going over paint/poly filler, I plugged the old instrument holes and faired it all in. I have no problem with sanding, I just want to attach the panel with good strength and the minimal amount of material between it and the dash.
  9. #23
    Any epoxy glue would work. For quick and easy try some JB weld. Scuff and clean first.
  10. Thanks Old_Skool thanked for this post
  11. #24
    ...four screws. gauges brackets will do the rest. no dash prep required...
  1. Best Prep/Primer/Paint combo to keep paint on LU?
    By imq707s in forum General Boating Discussion
    Last Post: 10-08-2019, 11:44 AM
  2. Removing bottom paint by wet sanding??
    By Novak7669 in forum Appearance Mods
    Last Post: 08-13-2013, 08:34 PM
  3. Hull Cleaner For Paint Prep
    By INXS in forum Fiberglass and Composites Discussion
    Last Post: 07-30-2009, 11:23 AM
  4. prep and paint
    By swit72 in forum General Boating Discussion
    Last Post: 02-28-2003, 11:46 PM
  5. Paint prep.....
    By Dave Estes in forum Technical Discussion
    Last Post: 08-18-2001, 11:41 PM
