Results 1 to 15 of 29
Thread: Lithium battery suppliers?
12-13-2021, 08:37 PM #1
Just wondering who has the best batteries at the best prices, I've done some research but never having owned any not sure about brands, thanks again
(Rip. Whiteally02) -dad
Smalltownbassin liked this post
12-14-2021, 07:22 AM #25000 RPM
- Dec 2019
- Spring Lake MI
- 495
- 38
- 155
- 450
Relion seems to be a great one for boats, probably the direction I will go some day.
TJ @ Baker Engineering
Tuff 24 300xs
Tuff 16 90 Yammie
3.75@199mph with LSX power!!!
Will hedrick thanked for this post
12-14-2021, 07:44 AM #3
Ive used Battleborn Batteries for years now without any issues. I was actually the first customer of theirs to use them in a marine application years ago. There have been countless youtubers dissect them to prove the quality compared to other brands. They are a bit higher than the competition but like most things, you get what you pay for. We just shot a new release video for the 50 and 75 amp hour group 24 12vdc units that are under $500. Most people find that the 50AH suits their needs fine without having to spring for the 100AH model.
12-14-2021, 08:47 AM #4
I've used EarthX in my motorcycles, and they perform flawlessly. They can make pretty much anything for any application, maybe worth a shot contacting them. They're a quality piece, and made in USA. Great people to deal with.
12-15-2021, 02:06 PM #5
Ionic batteries hands down. Not only good lithium batteries but also have a Bluetooth to your phone so you know exactly how much charge is in your battery without getting a single meter out. The app can tell you the amp draw the amp being charged temperature you name it it's really nice. Let me know what you think I can help you out with them
Will hedrick thanked for this postForkin' Crazy liked this post
12-15-2021, 02:18 PM #6
I have seen the Bluetooth feature and that is really nice, I need a24v for trolling, mainly to cut down on rear end weight and space, I have seen the 100 ah and the 200 ah,I want to make sure that I have enough power to get through a long day of trolling if necessary, also would need the appropriate charger
12-15-2021, 02:31 PM #7
In most cases 24 and 36 V trolling motors can get away with 2_50AH or 3_50AH batteries. I have a 55 Pound thrust motor mounted minkota with a single 50AH at 1.5 mile an hour or 10 AM draw I can run for 5 hours constant. Now as you know a 24 V trolling motor uses less amps that's why I say you can probably get away with the fifties if you're planning on running a trolling motor only area then I would highly recommend you jump to 2 100 AH. Now I will also tell you that 5 hours wasn't enough for us so I bought 2 more 50A h's now I have a 100 AH and should get 10 hours of trolling out of the 2 50 ah batteries. the 50AH 12 volt ionic batteries weigh 17 pounds
12-15-2021, 02:40 PM #8
They do make a single 24 V battery as well
12-15-2021, 02:59 PM #9
That's what I was gonna ask if you had them linked or a single cell, so those shut down before being completely drained? I have heard that if they get completely drained it will ruin them, not sure if that makes sense?
12-15-2021, 04:06 PM #10
That's a myth, I have run mine down till the BMS ( battery management system) shut them off, fishing was real good, did not hurt them. I would not recommend it however, and with the app you can monitor them. The nice thing about lithium batteries is they do not loose voltage, like wet or AGM batteries, the min you start using them, they run full voltage till they are dead.
There are 4 cells in a 50 AH battery. They run around 13-14Volts.Last edited by perfmarine1; 12-15-2021 at 04:11 PM.
12-15-2021, 05:46 PM #11
If you or someone you know deals in them, I would like a quote, I prob. Gonna pull the trigger on them before fishing picks back up in feb.
12-16-2021, 12:22 AM #125000 RPM
- Jul 2021
- Pompano Beach
- 144
- 16
- 38
12-16-2021, 12:29 PM #13
12-16-2021, 04:16 PM #145000 RPM
- Dec 2019
- Spring Lake MI
- 495
- 38
- 155
- 450
I also used a antigravity in my c5z with a 13.7:1 compression 438 and it spun the engine over FAST!it was 5.75lbs
Tuff 24 300xs
Tuff 16 90 Yammie
Will hedrick thanked for this postDavid - WI liked this post
12-16-2021, 04:22 PM #15
Thanks for all the responses and information, I'm prob going with the ionic batteries myself, seems like the right direction for what I'm going for
Going out testing a Harley lithium battery on a 300xs
By Pachanga_rick in forum General Boating DiscussionReplies: 22Last Post: 09-08-2017, 09:21 AM -
Lithium Batties
By jpf091959 in forum General Boating DiscussionReplies: 31Last Post: 06-28-2015, 09:56 AM -
Mercury Tech: How much juice needed to power 200xs / Lithium Battery question.
By Pachanga_rick in forum Technical DiscussionReplies: 9Last Post: 06-18-2015, 04:43 PM -
lithium battery charger
By bullwhipjkg in forum Misc. Parts and AccessoriesReplies: 1Last Post: 12-11-2014, 08:23 PM
