Results 1 to 14 of 14
12-08-2021, 08:21 PM #1Junior Member
- Jul 2021
- ca
2000 promax 225 water pressure issue
Freshly re built 2000 225 promax. During the break in period I seem to be having some water pressure issues. At idle im getting 1-2 psi and at fast idle slowly climbs to 4-5psi. The water pressure also fluctuates between neutral and drive while idling. However when getting from idle to 12/1300 rpm the water pressure climbs to 6-7 psi and then anything over that rpm the water pressure drops to nearly zero and then slowly starts to climb while getting on a plane. At 3500-4000 rpm the water pressure only reads about 4 with a broken to poor stream coming out of the pee tube. I replaced the impeller and thermostats were replaced by motor builder. Water temp has been between 140-155ish. While tuning at 3500-4000 rpm temp appears to slowly climb so I slowed down and you can see water temp drop to 140ish. Been hard to get pressures and temps while running under way since im still breaking in the motor. Poppet valve?? should the pee stream be a solid straight stream while under way?? thanks for the info
12-08-2021, 08:28 PM #2
You running a poppet or no?
12-08-2021, 08:36 PM #3Junior Member
- Jul 2021
- ca
yes running a poppet.. I haven't taken it out to look at it yet as the boat is stored at the river 4 hours away
12-09-2021, 06:06 AM #4Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Assuming the motor is completely stock and that you put in correct thermostats, I would start with the poppet and go from there. Use the search function on this site, there is a ton of info on Promax cooling.
12-09-2021, 01:01 PM #5
Do a full poppet valve kit, make sure the plastic insert in block is not loose or cocked in block.
12-09-2021, 04:34 PM #66000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 431
- 64
- 434
- 452
My p-max gauge reads 150 ish all day.poppets do cause fluctuation on start-up & low speed range.
12-09-2021, 05:09 PM #7
12-09-2021, 08:13 PM #8Junior Member
- Jul 2021
- ca
12-10-2021, 10:15 AM #95000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
Pro Marine can hook you up.
12-13-2021, 07:10 PM #105000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
Make sure the hoses on motor aren't blocked, mine had the purdy blue fuel hose on the thermostats, the liner in hose closed off and burnt motor so check plz
12-13-2021, 10:01 PM #11
Are you running a 1 or 2 piece exhaust plate
12-14-2021, 06:07 AM #12
Do you have a new complete water pump kit? Or at the bare minimum a new impeller.
12-14-2021, 01:38 PM #135000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
Temp. On that PM can be tricky. Friend of mine burnt one on first break in trip
12-17-2021, 07:21 PM #14Junior Member
- Jul 2021
- ca
2.5 water pressure issue??
By 16ft superboat in forum Technical DiscussionReplies: 6Last Post: 04-27-2015, 06:01 PM -
water temp/pressure issue on a 225 pro max
By John Dorn in forum Technical DiscussionReplies: 7Last Post: 08-02-2011, 05:27 AM -
Water pressure issue
By Cmack in forum Technical DiscussionReplies: 3Last Post: 02-03-2010, 11:48 AM -
2000 Promax High Water Pressure Issue
By Big E in forum Technical DiscussionReplies: 9Last Post: 11-09-2009, 04:13 PM -
water pressure issue...
By stlcheckmate in forum Technical DiscussionReplies: 13Last Post: 06-07-2008, 07:14 AM
