Results 1 to 5 of 5
    Dec 2021
    NV
    1985 Mercury 175 2.4L - Chrome or Steel Cylinders
    I am having trouble identifying the cylinder material (Chrome or Steel) for a 1985 Mercury Black Max 175 2.4L engine. I contacted Mercury but they could not help based on the serial number which is A136908. I recently purchased the boat/motor. The engine did get hot but did not seize. Compression was low but I replaced head gaskets and had the heads resurfaced and it brought all cylinders up to a reasonable compression level (126 high, lowest about 110). Motor starts and runs OK in a tank. A little piston slap and I have yet to launch for a lake test.
    Can anyone assist with identification of the cylinder material from the pictures included? It would be nice to know my options going forward.
    Any assistance would be appreciated.Click image for larger version.
ID:	497755Click image for larger version.
    Mar 2004
    Brooklyn Park, MN
    should be chrome. Stick a magnet on them all and you will know.
    1973 Viper
    1978 Viking
  3. Likes TEXAS20225 liked this post
    Dec 2021
    NV
    Thank you rjdubiel for your insight. I will check that next time I have the heads off.
    ...on a chrome motor thats been overheated, check for cylinders being out of round. top to bottom.
    Dec 2021
    NV
    Thanks
    Thank you FUJIMO. I am hoping I can use this motor and the 1986 Commander boat for a while without opening up the crankcase. Taking a risk I know. I will know more after the first lake test. Seems to start and run good in a tank. I realize that is a no-load condition. It shifts fine into forward and reverse. Lake test has been delayed due to trailer registration delays. I am in NV but waiting on CA DMV (arg!). Cant wait to get it on Lake Mead for an initial run.
    Obtained the boat/motor/trailer at a cheap price from the original owner. The overheating was at idle, operator heard clicking which turned out to be a stripped key on the water pump impeller. Saw smoke from under the cowling which turned out to be scorched foam on the inside of the clamshell cowling halves. Also the idle stabilizer and oil injection alarm modules were slightly melted. He immediately shut it down and was towed in. Since I bought it I have done the following:
    Milled heads, reinstalled with new gaskets
    Replaced Starter
    thermostats and spark plugs
    restored Water Pressure gauge hookup
    Poppet valve Rebuild
    Added Temperature Sender and buzzer for overtemp alarm
    Added Temperature and gauge for operating temp
    Removed Oil Injection
    Removed Idle Stabilizer module and re-timed
    Rebuilt carburetors
    Rebuilt fuel pump
    Changed gear oil
    Replaced leaking exhaust gasket (minor leak from the cooling jacket, looked like it had been leaking for a while)
    Previous owner replaced the water pump.
    I have a video of it running here:
    https://www.youtube.com/watch?v=9OFm1PoKGQo
  1. Removing Stubborn Melted Aluminum off of Chrome Cylinders
    By Krazymaan in forum Technical Discussion
    Last Post: 04-09-2017, 03:29 PM
  2. Mercury Tech: 1985 90 hp six dropping cylinders
    By Riverman in forum Technical Discussion
    Last Post: 05-24-2012, 10:21 AM
  3. Chrome Cylinders on 85 Mariner 150? HELP?
    By imthemedic in forum Technical Discussion
    Last Post: 12-18-2009, 12:40 PM
  4. Honing Our Chrome Bore Cylinders?
    By Glasply150 in forum Technical Discussion
    Last Post: 11-05-2005, 05:56 PM
