Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 53 of 53
  1. #46
    about 7k
  2. #47
    Quote Originally Posted by Mark75H View Post
    about 7k
    And what is this monster of 275psi , what exhaust configuration?
  3. #48
    Aug 2021
    Osteen/Deltona, FL
    Quote Originally Posted by Merc 2.5 View Post
    What kinda fuel or real octane booster , or mix of fuels do I need to run 170lbs compression? This will b a 1st for me and don't wanna burn her up
    Check out Boostane marine. It is not your auto parts store octane gimmick, its the real deal octane additive. I'm a performance calibrator for a living and we use it to take 93 to over 100 on a weekly basis on the dyno.
    83 Vking 150 Mariner 2.5L - re-core in progress
  4. Thanks Merc 2.5 thanked for this post
    Likes CI STV, Noah Burns, Merc 2.5 liked this post
  5. #49
    Apples to oranges but,
    When we lived in Fla I ran Av gas in all my hi comp motors.
    In the areas popular w/the airboats, you can get it at local gas stations.
    If not, local airports.
    I was running OMCs though that are much larger bore than a 2.4/2.5 Merc so our junk won’t put up w/what your Mercs will.
    At 170 lbs I was mixing 100 oct av w/93 pump w/no problem.
    Lightly loaded.
    As in, drag set up.
    W/no other changes other than adding:
    A passenger
    20 gls fuel
    A 30” lake wheel
    It ran a 1/2 mile before detonating itself to pc’s!
    On the smaller Merc bores, I’m sure it would have been fine.
    Just remember to figure in loading, to your equations ; )
    Remember too, compression on a 2 stroke is way different than a 4 stroke.
    Due to firing twice as often, the combustion chamber builds/retains so much more heat than a 4 that you hit a point of diminishing returns way quicker.
    For drag you see the positives way longer.
    For lake, I think that 170 is as high as I would attempt for an OMC Looper.
    For a Merc you can probably add at least +10 to this.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  6. Thanks CI STV thanked for this post
    Likes Merc 2.5 liked this post
  7. #50
    Sep 2017
    Ashland city tn
    My thinking is I run 145/150 as norm setup but on weekend I just wanna ride , I can pull weight out of it , swap heads to 170lb ,throw some fuel in ,and let her ride. Is it a good idea to do a jet change goin from 93 to mix of 93 and 100 or 110 just less of it. ?
  8. #51
    No jet change needed unless you were fat just to be fat.
  9. #52
    Sep 2006
    Texarkana, Arkansas
    I have been running 93-91 ethanol free fuel due to supply issues in my area mixed with ACES for years. I do run lighter weight, low pitch props but here is some better details on it.
    https://www.screamandfly.com/showthr...highlight=ACES
    1992 STV River Rocket - bottle fed 260
  10. #53
    Jun 2014
    United States
    Yesterday I ran my warmed up 2.5 225 hp mariner with 164 pounds of compression on 93 octane pump gas and 1 ounce of aces per 6 gallons of fuel. No problems whatsoever with this concoction.
  11. Likes Merc 2.5 liked this post
  1. Compression And Fuel
    By seansbaja1982 in forum Technical Discussion
    Last Post: 08-20-2019, 12:33 AM
  2. 2.5 compression and fuel
    By ActivatedSludge in forum Technical Discussion
    Last Post: 10-07-2012, 03:32 PM
  3. Compression And Fuel
    Last Post: 08-01-2012, 12:26 AM
  4. Fuel/compression/timing
    By 850cc racer in forum Technical Discussion
    Last Post: 11-02-2011, 07:59 AM
  5. Compression / fuel
    By JTS Racing in forum Technical Discussion
    Last Post: 07-29-2002, 06:29 AM
