Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 56
    Sep 2017
    Ashland city tn
    Fuel/compression
    What kinda fuel or real octane booster , or mix of fuels do I need to run 170lbs compression? This will b a 1st for me and don't wanna burn her up
  2. Likes Instigator liked this post
    Sep 2017
    Ashland city tn
    https://youtu.be/JWOevmVGwY8
    I finally figured out video to put on here. These are not the tight heads
  4. Thanks Keaten thanked for this post
  5. #3
    Have an airport near by?
    Los Angeles Cal.
    170 psi cranking on a 2.5 25° timing should be good at 95.5 to 96 octane. Been running that mixture for years with no problem. Mix avgas with pump premium or 110 race fuel with pump premium, works for me.
    Jun 2018
    Floating around
    VP110 is rated up to 12:1 compression. Not sure what 170 works out to but if thats not enough go higher
    https://vpracingfuels.com/product-category/marine/
    Sep 2017
    Ashland city tn
    Yep
  9. Likes Instigator liked this post
    Sep 2017
    Ashland city tn
    Quote Originally Posted by Stoker boy View Post
    What's the ratio tho
    Florida Keys
    Two stroke “compression ratio” doesn’t jive with what the fuel companies talk about for four stroke engines.
    like said above…..go to the airport and get some 100LL and you’ll be plenty safe for 25-26 degrees of timing. For the most part, Any engine is going to make its most power on the lowest octane fuel you can run before detonation so if you want to get picky you might pick up a few mixing down to 96 octane or so. In my experience the gains aren’t worth the risks so I’d rather be over and safe…just my opinion…
    '95 STV "The Blue Goose"
    Los Angeles Cal.
    Quote Originally Posted by Merc 2.5 View Post
    If you want to know how to compare your 2.5 two-stroke in automotive four stroke engine terms like 10:1 compression ratio. Go online and look at compression ratio explained, however in my opinion doing that on your two stroke would be a waste of time.
    As far as mixing goes. 2.5 gallons of 91 pump premium = 227.5 + 2.5 gallons of 100 aviation fuel = 250 Total they equal 477.5. Divide that total by number five because it’s 5 gallons = 95.5 octane.
  13. Thanks Merc 2.5 thanked for this post
    Likes Merc 2.5 liked this post
    Oct 2015
    Kentucky lake
    The Air port I work at sells 100LL .I get to smell it burning in Airplanes all day long.. Smells great !! Right now it's 6.00 a gallon. I use it all the time in my boats/ ATVs /Sport Bike love it !!
  15. Likes Capt.Insane-o liked this post
  16. #11
    I ran 100ll av for years at 175-180 psi.
  17. Likes H2OPERF liked this post
  18. #12
    It has a much better shelf life to. I run it everything that isn't used on a weekly basis and I put hundreds of gallons thru my X motors over the years.
    Los Angeles Cal.
    Quote Originally Posted by Keaten View Post
    I bought some 100LL last week $5.53 a gallon. 110 race fuel $12.50 a gallon.
  20. #14
    I think a lot of politicians own airplanes .. not many hang out at the track ..
  21. Likes CI STV, cameronj liked this post
  22. #15
    Los Angeles Cal.
  1. Compression And Fuel
    By seansbaja1982 in forum Technical Discussion
    Last Post: 08-20-2019, 12:33 AM
  2. 2.5 compression and fuel
    By ActivatedSludge in forum Technical Discussion
    Last Post: 10-07-2012, 03:32 PM
  3. Compression And Fuel
    Last Post: 08-01-2012, 12:26 AM
  4. Fuel/compression/timing
    By 850cc racer in forum Technical Discussion
    Last Post: 11-02-2011, 07:59 AM
  5. Compression / fuel
    By JTS Racing in forum Technical Discussion
    Last Post: 07-29-2002, 06:29 AM
