Results 1 to 15 of 30
Thread: Outboard Engine Hoist
12-06-2021, 04:50 PM #15000 RPM
- May 2001
- Maine
- 983
- 35
- 43
- 171
Any thoughts or recommendations on pulling a 3.0L Mercury with a automotive engine hoist like the ones at Harbor Freight or Tractor Supply. Just going to add some set back and need to unbolt and separate for a hour or two. I plan to use a safety chain/ cable/ strap to the garage 2nd story floor joist just incase. Not sure I want to rely on the joist unless $%*! happens.
12-06-2021, 05:45 PM #2The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...too much weight for an overhead wood floor joist for any length of time. beg, borrow or steal a real lift of some sort...
12-06-2021, 06:47 PM #3
I made my neighbor a pair of aluminum covers to go over the rafters in his garage. He puts a piece of pipe across the two and uses a chain hoist to pull and replace engines with his kid. Personally, I don't recommend using the house as a tool .. but ...
I have a cherry picker that comes apart and stores in the corner of my motor room.
To get motors in~out~and around, I made another one that plugs into my hitch.
My trailer needs a little work , so I'm thinking about a couple wooden gantry's, chain hoists and slings. That stuff always comes in handy.
Come to think of it, I have some I-beams layin around. I could make one out of steel and buy a trolly for it ... Yea- I know, overthinking a simple job ..
Rigaud liked this post
12-06-2021, 06:55 PM #46000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 341
- 174
I have been using a Harbour Freight folding engine hoist for lifting outboards for nearly 10 years - works great. The key tool is actually the correct lifting eye for your motor.
Matt
12-06-2021, 07:00 PM #5
If you spread the load garage rafters can support the weight.
When I was 18 I pulled motors out of cars in my moms garage and all I did was sling a chain over one rafter and hooked up the chain fall. Can't believe we didn't pull that garage down on our heads, lol
because I'm older and (slightly) wiser I borrow my friends engine hoist, it is from hobofreight, works fine.2023 Progression 22 w/ 2015 Mercury 300XS. 2018 Kawasaki Ultra LX. 1969 Hustler Wildcat. 1985 Hydrostream Vegas XT. Gone but not forgotten: 1991 POS GW Invader. 1976 Donzi Hornet II. 1994 Formula 232 LS. 2001 Regal 2660. 1990 Formula 206 LS. 1992 Checkmate Pulse 186 w/ 2003 Mercury 200 EFI. Random assortment of jet skis.
rgsauger liked this post
12-06-2021, 07:37 PM #6The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...knowing how thin a material a ford or chevy 1/2 ton pickup truck frame is...that lift in the reciever hitch looks scary chaz...cantilevered out like that...
12-06-2021, 08:16 PM #75000 RPM
- May 2001
- Maine
- 983
- 35
- 43
- 171
I was thinking about taking a 4x4 or (2) 2x6 spiked together about 8' long and placing them on the 2nd story floor joist plywood so as to distribute the weight and dropping a chain down through a pre cut hole floor as from what I can find out the engineered joists can support 40-50 lbs./ sq' and mine are 2' on center but I would be a little nervous.
Suppose given the cost of the motor & lower vs. the cost of a foldable lift, I could always craigslist the lift after I am done.
12-06-2021, 08:23 PM #8Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Unbolt it and tip the boat over...
hydroo liked this post
12-06-2021, 11:16 PM #9
12-06-2021, 11:36 PM #10
Regular engine hoist will do it but sometimes you run into lifting restrictions, start touching the flywheel with the arm, but usually you can make something work. Just pulled my Optimax off with a hoist a week ago. Lower was off, so I placed the exhaust housing down on a piece of wood and left tension on the hoist attached to the flywheel. That's where it sits today
www.InjectorService.com
Call/Text - 204-326-0390
12-07-2021, 08:12 AM #115000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
12-07-2021, 08:36 AM #125000 RPM
- Dec 2019
- Spring Lake MI
- 497
- 38
- 155
- 450
I used a good old engine hoist for my 300xs and it worked great.
TJ @ Baker Engineering
Tuff 24 300xs
Tuff 16 90 Yammie
3.75@199mph with LSX power!!!
12-07-2021, 09:59 AM #13
12-07-2021, 12:20 PM #14
Had to get creative
Attachment 497712Last edited by Baker343; 12-07-2021 at 03:40 PM.
XstreamVking, Old_Skool liked this post
12-07-2021, 01:14 PM #15
I dont see why that wouldn't work, letting ti hang there for a few hours probably wont be too bad, you could always let the lower unit stand on a block of wood to release some of the weight on the joists if you need to hold it longer, but anyways my dad an I both have hoists in our garages connected to eye from the joists...He was able to put a piece of wood over the joists to connect the eye to and I have a floor over my garage so I rigged up a few pieces of steel angle to bolt into the joist...Ive had a 2.5 swinging on it pretty good before and the drywall hasnt cracked yet lol
I find I am using my in-garage ceiling hoist more often because its easier to back the boat in...the portable one I use if I am on the road...
Twin outboard engine swap to single outboard same Hp
By Narcoholic in forum General Boating DiscussionReplies: 24Last Post: 06-14-2021, 06:47 PM -
Engine Hoist
By JRider in forum Technical DiscussionReplies: 5Last Post: 07-21-2003, 02:53 PM -
I want to buy and engine hoist? Where?
By promax150 in forum General Boating DiscussionReplies: 11Last Post: 10-31-2002, 03:11 PM
