Results 1 to 15 of 22
Thread: Merc lower question??
12-05-2021, 09:10 PM #15000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
2.5 lower on my 175hp Merc making a grinding noise when putting in forward only reverse is normal. Coming back to netural always normal both with F and R. It's the normal quick grind noise but longer no Madder how you do it fast or slow. Once in forward it's all normal at all rpms. Just started yesterday.
12-05-2021, 09:36 PM #2
Have you changed or pulled the lower recently? If so shift shaft could be out of sync, but it could be a chipped gear, possibly getting ready to sling a bearing it sounds like
(Rip. Whiteally02) -dad
12-05-2021, 09:39 PM #3The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...just started after previously normal? stop. disassemble & diagnose. save $ on self-destruction...
Will hedrick, rock liked this post
12-05-2021, 11:10 PM #45000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
That was my gut feeling too!!
I'll drain oil tomorrow and look for metal shavings.
Then pull it off
12-07-2021, 05:12 PM #5
Get ready to get creative when pulling that bearing carrier lol
12-07-2021, 08:04 PM #697 xb2002 15" 300x w 1.62 sporty
12-09-2021, 09:30 PM #7
Will hedrick liked this post
12-09-2021, 10:01 PM #8
That will work better then my redneck engineering
12-10-2021, 10:12 AM #95000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
Pinion
12-10-2021, 04:04 PM #10
Best case scenario the bearing carrier nut zips right off and you can use a simple 2 jaw puller to pull out the bearing carrier...
Worst case scenario you have to drill out the carrier nut, chisel it apart, and then rig up some spacers under a prop to use as a press to get get the bearing carrier out, dont forget to remove the shift shaft first because you are using the prop shaft clutch dog to pull on the reverse gear
12-10-2021, 09:32 PM #11
When they are stuck stuck you just break out this.
12-10-2021, 09:55 PM #12
12-10-2021, 10:32 PM #13
Speaking of carriers, this is my first sporty, so you still need to pin the carrier? I pin the carriers on my L2 m2 omc conned lowers previously. Just curious on opinions
12-13-2021, 12:58 AM #14
12-13-2021, 05:11 AM #15
if ya need ta "pin" a merc carrier and/or nut, might as well float test it and start over.... jmo
Capt.Insane-o liked this post
Merc lower unit question
By lbhsbz in forum Technical DiscussionReplies: 5Last Post: 06-05-2013, 01:57 PM -
Merc 3.0L Lower unit question
By Go Time in forum Technical DiscussionReplies: 11Last Post: 12-12-2011, 07:14 AM -
merc lower unit question
By ernstudet22 in forum Technical DiscussionReplies: 4Last Post: 03-27-2008, 10:16 AM -
Merc 3 Liter Lower Unit question
By Moodgam in forum Technical DiscussionReplies: 2Last Post: 05-23-2005, 08:26 AM -
Merc Lower unit question
By dmbusch in forum Technical DiscussionReplies: 4Last Post: 04-18-2002, 08:41 PM
