Results 1 to 9 of 9
    Dec 2011
    Ball Ground, GA
    1999 Mercury Torque Master 2.5l Gear Case
    1999 Mercury Torquemaster lower unit. 20" shaft. New water pump impeller, and synthetic gear lube. Bolt on and go. $1400.00 Any questions, please call Jeff Wilson 404-895-6795Click image for larger version.
ID:	497407Click image for larger version.
    Feb 2020
    Texas
    Is a Coned?
    Dec 2011
    Ball Ground, GA
    No, its just a real clean stock unit
    Jul 2013
    Where did you get that gearcase stand?
    Dec 2011
    Ball Ground, GA
    Boaters best. I believe there is a website u can order from.
    Jul 2013
    Saw that name in the side of the stand. Can’t find anything on the stands.
    Remember seeing plans to make them in the past. Can’t find that either.
    Aug 2009
    mpls,mn
    Quote Originally Posted by swilson3136 View Post
    even though it's stamped 1:87 can you verify that please.
    Dec 2011
    Ball Ground, GA
    Yes, Its 1.87-1 non coned stock unit.
    Dec 2011
    Ball Ground, GA
    Sold Thanks S &F
  1. Mercury optimax 3.0 torque master gear case identification LH or RH
    By Narcoholic in forum Technical Discussion
    Last Post: 07-31-2021, 09:07 AM
  2. 3 ltr torque master gear case water pick up
    By 30velocity in forum Technical Discussion
    Last Post: 01-31-2021, 10:19 AM
  3. Replies: 1
    Last Post: 10-17-2019, 09:12 AM
