Results 1 to 15 of 21
    Mar 2007
    Ontario, New York
    WTB: X-Front for V6 OMC Looper
    Like the title says looking for a X-Front for V6 OMC looper.
    Dan Cario
    1994 STV Mod-VP w/225HO Ficht Evinrude
    1987 22' Velocity w/225HO Evinrude E-Tec
    Aug 2019
    Palmharbor
    Do you know who makes the adaptor for Merc lower unit to fit on rude mid
    Mar 2007
    Ontario, New York
    Quote Originally Posted by MrG View Post
    Sam Jenkins or Monty would be ones to ask. Alot of guys that are running 3L Torq/Sport Masters just weld and redrill the mounting flange holes on the lower to the OMC pattern and not using any adapter plate at all.
    Dan Cario
  4. Thanks Instigator thanked for this post
    Likes Instigator liked this post
    7 Post(s)
    I think that only works on the 3.0 Sportys?
    Quote Originally Posted by Baja16 View Post
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
    Mar 2007
    Ontario, New York
    I personally have a 3.0L sporty that Kevin did. I know several people that have welded up the Torquemaster flange and redrilled them as well. The Torquemaster does have a thinner flange but the guys I know who've done it haven't had any issues.
    Dan Cario
    7 Post(s)
    What I meant was 3.0 Sporty Vs 2.5 Sporty.
    They have different mounting patterns.
    Dec 2001
    Cheat Cheat.................
  9. #8
    Dec 2001
    Lets get Down......Nobody has made a Gearcase......worthy of the speeds you are going.......Phiffit..........D ...S....
  10. #9
    Mar 2007
    Ontario, New York
    Yup I misunderstood ya. Yes 2.5 cases are gonna need a adapter plate (or again Sam Jenkins makes the 16" Taylor mid that has the OMC upper and the Merc 2.5 lower).
    Dan Cario
  11. #10
    7 Post(s)
    Was more towards answering Mr Gs question.
    Ive done a couple of the (OMC) 16” Taylor mids (before Sam got them) w/Merc 2.5 liter Sportys.
    The 3.0 Sportys have way bigger water pumps which are mandatory for a V-8 looper and preferable on V-6 loopers.
    The bonus is how easy they are to mate to OMCs.
    As you noted, weld up and redrill OEM bolt locations.
  12. Thanks MrG thanked for this post
    Aug 2019
    Palmharbor
    Thanks for the info building a 3.3 monster and I have a fat shaft torque master and a empty 3.0 sporty case also a lightning case with a cone ( not a Bobs) was just checking my options thanks for the insite
  14. #12
    Aug 2019
    Palmharbor
    Ok so wile we’re on the subject one ram system is that too much work to make fit
  15. #13
    Aug 2019
    Palmharbor
    Can we use the omc swivel shaft and lower mount on a one ram trim and ears just your thoughts on that thanks
  16. #14
    7 Post(s)
    Chaz does the conversion to a Merc single ram for the 16” Taylor/Jenkins mid.
    Which is the best option.
    The two I’ve done, we cut down the OMC trim/clamp assembly which deletes the OEM trim ram pads/pickup.
    You then fab up guides that allen screw to the back of the clamp saddles.
    Best is to then install bronze trim tube bushings in place of the OEM nylon versions.
    Works for light duty but not the best route, and not long in rough Svc.
  17. Thanks MrG thanked for this post
  18. #15
    7 Post(s)
    Sorry for hi-jacking your thread Baja.
    Way more to it than that G.
    Many threads on here in re to it.
    PM/call me and I’m happy to help.
  19. Thanks MrG thanked for this post
    Likes MrG liked this post
