Results 31 to 36 of 36
01-05-2022, 02:34 AM #315000 RPM
- Jun 2021
- Australia
- 190
- 9
- 15
01-05-2022, 02:36 AM #32Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
great news
you now need to set the timing pointer and check the max timing
01-05-2022, 02:38 AM #335000 RPM
- Jun 2021
- Australia
- 190
- 9
- 15
Yes, thanks. I'll rebuild the carbs and inspect reeds first and then attempt a startup. Stay tuned.
01-05-2022, 10:24 AM #34Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
When you set pointer, make certain TDC is mid point of dwelled crank rotation degree range piston stopped.
01-26-2022, 04:49 AM #355000 RPM
- Jun 2021
- Australia
- 190
- 9
- 15
01-26-2022, 05:19 AM #36Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Fitting post '78 OMC V4 transom bracket to '75 model motor
By Gilera in forum Technical DiscussionReplies: 6Last Post: 09-27-2021, 10:10 AM -
Mercury 15" 1500 inline 6 Battery Ignition system & Charge system specs
By scott reierson in forum Technical DiscussionReplies: 4Last Post: 10-01-2020, 07:27 PM -
Locking Gas Cap To Fit Perko Model 540 Deck Fitting
By WaterZebra in forum Technical DiscussionReplies: 7Last Post: 06-16-2018, 03:20 PM -
Johnson 70 Horse - Pee Tube Drill /Tap Location for Old 1975 Model
By Gordon02 in forum Technical DiscussionReplies: 5Last Post: 04-22-2018, 09:43 AM
