Results 16 to 30 of 36
12-15-2021, 08:40 PM #16Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
12-16-2021, 05:13 AM #175000 RPM
- Jun 2021
- Australia
- 190
- 9
- 15
I just tried the trigger and it does bind on the top of the crank. I guess there goes my idea of transplanting the later system and back to troubleshooting my own.
12-16-2021, 05:21 AM #18Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
12-16-2021, 05:41 AM #195000 RPM
- Jun 2021
- Australia
- 190
- 9
- 15
Not the diameter but the height of the recessed area inside the trigger. It hits the top of the upper crank bearing housing. I thought about swapping them over but after I undid the 4 bolts I couldnt get it off. Is there a trick to it?
12-16-2021, 06:15 AM #20Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
12-19-2021, 09:47 PM #215000 RPM
- Jun 2021
- Australia
- 190
- 9
- 15
This bearing carrier is STUCK. Tried undoing crankcase bolts and heating it up. Levering up from various different points. Looks like just an o ring under it - do they normally come off pretty easily if not glued on?
12-21-2021, 10:18 PM #225000 RPM
- Jun 2021
- Australia
- 190
- 9
- 15
I got a new battery 100ah yesterday as my old one was dying. Engine spins very quick now. Still I was only able to get a weak yellow spark and only when the plugs were out.
12-27-2021, 03:03 AM #235000 RPM
- Jun 2021
- Australia
- 190
- 9
- 15
Not sure if anyone is following this but i finally got the bearing carrier off the 1980 model 85hp. There is one threaded hole in the back of the carrier to the right. Its that same thread size as the 4 bolts that hold it in. I took one of the bolts and ground down the head so it would fit in the head of my slide hammer. It took a bit but it finally came off. I then used the same technique for the 1975 model which came off alot easier. Next step is to fit all the electrics from the newer motor and see whether it works. Any advice on how to mount the power packs and coils would be welcome!
12-27-2021, 04:04 AM #245000 RPM
- Jun 2021
- Australia
- 190
- 9
- 15
That was short lived excitement. The other bearing carrier doesn't seem to fit in the housing of my 1975 model. Must be just the tiniest bit wider so you can't get it started. I could try chamfering the bottom edge below the first O ring with some sandpaper?
12-28-2021, 04:59 PM #255000 RPM
- Jun 2021
- Australia
- 190
- 9
- 15
Tried chamfering the bottom edge without success. The current replacement part numbers are the same for these two motors so I guess the diameter should be the same. Perhaps just variation from the factory. I can put the original bearing carrier back in my 1975 ok and it will slide down into the housing, but can't get the 1980 model one into it. I read in the factory manual that when reassembling the motor you normally put this "upper crank assy" in before bolting the crankcase together. I could try to remove the top bolts as advised to remove the stuck one but that was a seized motor that I didn't care about. If I do this i'm worried that I run the risk of the crankcase not sealing anymore.
12-28-2021, 08:23 PM #26Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
12-28-2021, 09:02 PM #275000 RPM
- Jun 2021
- Australia
- 190
- 9
- 15
That's what I had thought before I tried to swap them. What it seems like is that the original part for the 1975 model 0385504 has been replaced with the original part number for the 1980 model (0387432). Given the difference in shape I can see how the earlier timing base would be compatible with the later bearing carrier but not vice versa. My photo in post #15 is not the best but if you look carefully you can see that there is more of the shoulder cut away in the later model. The shoulder of the earlier bearing carrier is what interferes with the inside top of the later model timing base.
There is no difference underneath but you can see some deep scoring in the one I got from the 1980 model seized motor.
Off 1975 motor:
Off 1980 motor:
12-29-2021, 05:17 AM #28Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
12-29-2021, 04:29 PM #295000 RPM
- Jun 2021
- Australia
- 190
- 9
- 15
01-05-2022, 02:27 AM #305000 RPM
- Jun 2021
- Australia
- 190
- 9
- 15
Well I managed to get the later model bearing carrier in at least for testing purposes. It needed a bit of careful sanding to fit. Unsure if it was a result of the engine it was fitted to destroying itself or variation in tolerance from the factory. I made some brackets for the power packs. They look a bit asymetrical but i used aluminium angle and wanted it to sit flush with the original mounting points for the single power pack so that they would be more rigid. They feel very secure. The mounts are a bit different on each side. I could mount 2 coils in the original place for the 3 bolts coils that were on the '75 model, I could use one hole for the other 2 coils but made mounting plates to angle the other 2 in a way that fits. I still need to route the wires better and will replace the bearing carrier with a better one if I can find one as it has been knocked around and the bearing might not be the best. Anyway I turned it over and managed to get good spark from all 4 cylinders jumping a 7/16" gap on my spark tester!
powerabout liked this post
Fitting post '78 OMC V4 transom bracket to '75 model motor
By Gilera in forum Technical DiscussionReplies: 6Last Post: 09-27-2021, 10:10 AM -
Mercury 15" 1500 inline 6 Battery Ignition system & Charge system specs
By scott reierson in forum Technical DiscussionReplies: 4Last Post: 10-01-2020, 07:27 PM -
Locking Gas Cap To Fit Perko Model 540 Deck Fitting
By WaterZebra in forum Technical DiscussionReplies: 7Last Post: 06-16-2018, 03:20 PM -
Johnson 70 Horse - Pee Tube Drill /Tap Location for Old 1975 Model
By Gordon02 in forum Technical DiscussionReplies: 5Last Post: 04-22-2018, 09:43 AM
