Page 3 of 3 FirstFirst 1 2 3
Results 31 to 36 of 36
  1. #31
    Jun 2021
    Australia
ID:	499322Click image for larger version.
  2. #32
    8 Post(s)
    great news
    you now need to set the timing pointer and check the max timing
  3. #33
    Jun 2021
    Australia
    Yes, thanks. I'll rebuild the carbs and inspect reeds first and then attempt a startup. Stay tuned.
  4. #34
    When you set pointer, make certain TDC is mid point of dwelled crank rotation degree range piston stopped.
  5. #35
    Jun 2021
    Australia
    Finally got around to tidying up the wiring so it sits well away from the flywheel. Made a TDC tool from a spark plug and adjusted pointer. Getting close to being ready for startup. Click image for larger version.
ID:	500257Click image for larger version.
ID:	500258Click image for larger version.
  6. #36
    8 Post(s)
    Quote Originally Posted by Gilera View Post
    looks good
  1. Fitting post '78 OMC V4 transom bracket to '75 model motor
    By Gilera in forum Technical Discussion
    Last Post: 09-27-2021, 10:10 AM
  2. Mercury 15" 1500 inline 6 Battery Ignition system & Charge system specs
    By scott reierson in forum Technical Discussion
    Last Post: 10-01-2020, 07:27 PM
  3. Locking Gas Cap To Fit Perko Model 540 Deck Fitting
    By WaterZebra in forum Technical Discussion
    Last Post: 06-16-2018, 03:20 PM
  4. Johnson 70 Horse - Pee Tube Drill /Tap Location for Old 1975 Model
    By Gordon02 in forum Technical Discussion
    Last Post: 04-22-2018, 09:43 AM
