Results 1 to 9 of 9
Thread: 16" 3.4L Etec
    Bristol, WI
    16" 3.4L Etec
    2009 3.4L Evinrude Etec Powerhead with true 250 heads, Modified EMM with no rev limiter. With a small prop, this motor can spin 7200rpm no problem. It sits on a modified adapter plate. The Midsection is a Sam Jenkins 16" housing and modified clamp assembly. Solid upper and lower mounts. Shortened drive shaft and shift shaft. The lower unit is a Lightning L2 1.71 with low water pickup. I have extra lower units also for extra $. Cowl and pans are factory that I have lightened and dipped in carbon hydrographics. It's got some scratches/scuffs but still looks great. Oil tank included. New starter solenoid. This is a factory remanufactured block. 380ish total hours, 190ish hours since new EMM and remanufacture. I've owned this motor for 10 years and it's a strong runner. Has won multiple high points championships at Blarney Island in Lake Racer. Currently pushes my heavy Liberator to 100mph. Its currently mounted the boat but will be pulled off soon. I can help load it up for you. Call or text. $9995
    Larry 847 seven zero seven 2590
    https://youtu.be/_t0qdttbOwg
    Larry Gempp Jr.
  2. Likes Instigator, Capt.Insane-o, Greg G liked this post
    Bristol, WI
    Larry Gempp Jr.
  4. Likes Instigator, powerabout liked this post
  5. #3
    Nice boat, cool camera!
  6. Likes Instigator, Speed Jr. liked this post
  7. #4
    Mar 2016
    Winter Haven
    what kind of horsepower / what speeds would you see on a Mirage or StV
    That motor looks,runs and sounds great. Saw it in action on the TN river last year,
    Mar 2003
    Belvidere IL, FARM
    Oh man, this would be perfect on My Stoker. Dude is a perfectionist, so you know he's speaking truthfully.
    God, Country, and Fast Boats
    Nov 2003
    Fuel requirements?
    Jan 2021
    australia
    Still available?
    Bristol, WI
    Sold. Thank you.
    Larry Gempp Jr.
  1. 2010 150 Etec 20"
    By amt2007s in forum Outboard Engines
    Last Post: 08-12-2018, 09:11 AM
  2. Etec mid, going shorter than 20" ???
    By derpid in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 07-04-2018, 05:45 PM
  3. WTB or WTT Etec Magnum 25"
    By wingtime in forum Lower Units
    Last Post: 03-02-2017, 01:44 PM
  4. 2010 115 HO etec 20"
    By Mr. Action in forum Outboard Engines
    Last Post: 12-19-2014, 11:21 AM
  5. 12" etec
    By sinkorswim in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 08-16-2012, 05:09 AM
