Results 1 to 12 of 12
    Jun 2018
    Floating around
    Bore and sleeve 2.0L into 2.5L?
    doable?
    Jul 2004
    houston,tx
    2.0 motors were a steel casted part in the sandcast when alunimum was poured in to make the block
    2.0 was done this way from the beginning in the late 70s till 2.5 castings of the 90s
    not a slid in round steel sleeve like a 2.5 sleeve of the 90s
    also only has small boost ports casted ,,,hp 2.0s back then had milled in fingers not behind liner like 2.5
    only 2.0 made with all the behind the liner 2.5 goodies was the early 90s 2.0 bridgeport formula 1 motor
    gaylen burden did do us a very few 2.0 bridgeport 2.0s he bored and put in 2.5 sleeves
    so has a 2.5 bridgeport motor and was a beast for unlimited drags,,,,
    production block wise just getting a 2.5 ff block and doing some portwork and cavity work is way less work
    and more power over the small intake charge the 2.0 had being enlarged
  3. Thanks LakeFever thanked for this post
    Likes David - WI, LakeFever, Capt.Insane-o liked this post
    Jun 2018
    Floating around
    Great info thanks. I’m still learning about plenty about these motors but I have a couple 2.0L motors and I got to wondering and now I need not wonder a moment longer
    Dec 2001
    2.0..... bullet proff........no piston slop..... lasts for years,,, hone an go.....ya want power.... 2.5...dun rite......15 years and countin'......smmoth the ports.....I get sooo tired of tryin' to tell......... ben' buildin' for years.....why don't listen?....Ya don't know MePhifft
  6. Likes Michael J Giesler liked this post
    Dec 2001
    So long ago......
    PARADISE /Naples
    Talking to a guy at the Tenn. drag race, Bill Gore built his 260 pulled the sleeves behind the liner port work, ran good for a few passes till it broke
    Dec 2001
    Check the fuse........they might have rotated it and put it in wrong
  10. Likes rgsauger liked this post
    Houston, TX
    Hey Chaz, .22 shells make good fuse replacements in a pinch.
    Dec 2001
    Get up sobber......phifft
    Please keep things civil.
  14. #11
    Feb 2007
    lily lake WI
    Quote Originally Posted by CUDA View Post
    If it is the motor Steve Cleinmark had that work was done by Jim Ruck Bill just put it together when it was hurt Gohr has it Resleeved by his block Machinist
    Mike ,
    With any luck, you'll have better results with the truth than I did.
  1. bore or sleeve
    By demag67 in forum Technical Discussion
    Last Post: 02-23-2013, 10:28 AM
  2. Sleeve it, or bore it..?
    By Ted Stryker in forum Technical Discussion
    Last Post: 03-01-2010, 09:11 PM
  3. New sleeve or bore it?
    By artic rider in forum Technical Discussion
    Last Post: 09-16-2007, 01:25 PM
  4. to bore or re-sleeve
    By CharlieB in forum Technical Discussion
    Last Post: 08-17-2005, 05:30 AM
  5. 200 chrome bore. sleeve or not to sleeve?
    By fisherman in forum Technical Discussion
    Last Post: 01-02-2004, 05:20 PM
