Page 7 of 7 FirstFirst 1 2 3 4 5 6 7
Results 91 to 99 of 99
  1. #91
    Nov 2021
    Holland,Michigan
    What symptoms would i have if my floats in the same carb are set at different levels? Mine are in the bottom carb.
    What is the proper way to adjust the floats?
    From what i have found they should be set at a 1/16th, is that correct?
    1988 Bass Tracker 1800FS Tournament W/ Mercury 150 BlackMax 2.0
    With a need for speed!!
  2. #92
    Nov 2021
    Holland,Michigan
    The gap between the float metal tab and the wire on the needle. That should only be open enough for the metal tab on the float to fit through is that correct? Then I bend the metal tab on float to get my float hanging down 1/16th inch to the float bowl surface while upside down, is this correct? This is what it looks like with new needle and seat, with no adjustments.
    thanks.
ID:	499506Click image for larger version.
  3. #93
    Nov 2021
    N. Idaho
    I just sent you the photo out of the service manual looks like you have to adjust with bowl upside down at 1/16.
  4. #94
    Nov 2021
    Holland,Michigan
    Where can i get one of those manuals that you got that from? I want an oem manual that will show me everything like a service manual.
  5. #95
    Houston, TX
    I got mine on Ebay
  6. Likes OnPad liked this post
  7. #96
    Nov 2021
    N. Idaho
    E bay or I found one for a free download, but I had to look pretty hard.
  8. Likes rgsauger liked this post
  9. #97
    Nov 2021
    N. Idaho
    I can try to send one to you through text, but its for 92 and newer and 800 pages. Let me know.
  10. #98
    Nov 2021
    Holland,Michigan
    That's for sure.
  11. #99
    Nov 2021
    N. Idaho
    Wouldn't let me text it. Maybe email if you want to pm that. I wish I knew were I found that at, I would just send you a link.
  1. Heads identification (mercury 200 black max)
    By BigChief in forum Technical Discussion
    Last Post: 02-15-2018, 04:59 AM
  2. Need some Mercury v6 Identification help
    By gotboostedvr6 in forum Technical Discussion
    Last Post: 08-25-2015, 08:46 PM
  3. Black Max 200 Serial Number identification
    By maineidyl in forum Technical Discussion
    Last Post: 02-25-2014, 05:45 PM
  4. Mercury Tech: Mercury V6 Identification
    By jmadisonbiii in forum Technical Discussion
    Last Post: 05-29-2012, 02:50 PM
  5. 280 wiring Identification Red & Black wire On Starboard Side
    By rsjc in forum Technical Discussion
    Last Post: 02-20-2011, 01:56 PM
