Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 76 to 90 of 99
  1. #76
    Nov 2021
    N. Idaho
    My motas have senders in both heads. One for horn (tan with blue stripe) other for gauge (tan).
  2. #77
    Nov 2021
    Holland,Michigan
    Mine on the port side has two wires the one on the starboard side has just one grounded to the head. Port side is a tan and black wire, black wire is ground to head and tan went to the gauge.
    1988 Bass Tracker 1800FS Tournament W/ Mercury 150 BlackMax 2.0
    With a need for speed!!
  3. #78
    Nov 2021
    Holland,Michigan
    Im going to order my cc reeds, i would want the ones for 6500rpm correct or could i run over that with the correct mods. I dont want to short change myself for future possibility's.
  4. #79
    Nov 2021
    N. Idaho
    Your going to have alot of modifying or run a really short prop to get over 6500.
  5. #80
    Nov 2021
    Holland,Michigan
    Ok, thank you.
  6. #81
    Nov 2021
    N. Idaho
    Hey SJD1974. Your problem with engine losing power might be a little difficult to diagnose, because it is intermittent. I would recommend starting simple by replacing fuel hose and primer bulb. I've had problems with both especially the grey marine fuel hose. Then you might check your coils. Sounded like you had your carbs apart and cleaned them up. If you want to pm your # I'll text you testing procedures for your stator, swittchboxes and coils.
  7. #82
    Nov 2021
    Holland,Michigan
    The switch boxes that are on it now are not a matching set. I don't if the person before use didn't know you should replace them as a pair.
    Its been tough here with the temps in the 40,s and working on the boat, no real good way to test it, so its a do all i can before spring and then go like crazy testing it.
  8. #83
    Nov 2021
    Holland,Michigan
    Where is the best place for me to lift from on the motor to pull it off the boat
  9. #84
    Nov 2021
    Holland,Michigan
    Long enough for me to install a manual Jack plate
  10. #85
    Nov 2021
    N. Idaho
    I sent you a picture of the flywheel puller / lifting eye the other day. Only like 20$
  11. #86
    Nov 2021
    N. Idaho
    Anyone that works on their own mercury, should have one. Or a buddy you can borrow it from.
  12. Likes rgsauger liked this post
  13. #87
    Nov 2021
    N. Idaho
    That and a dva adaptor, or some sort of peak voltage tester.
  14. #88
    Nov 2021
    Holland,Michigan
    Can anyone tell me what the torque specs are for the reed cage bolts and the intake bolts are?
    I have all my parts
    Going to now clean the carbs, replace the needle and seats, put in the CCMS reeds, all new fuel lines from tank to carbs and everything in between, cleaned the tank inside and out, new bleed lines, new switch boxes(going to replace all terminals while doing it), going to add a jack plate to it(thanks ShadowFlier for you help with that) and move motor up 2.5 to 3 inches, removed oil injection completely, removed idle stabilizer black box and finally set timing to the range 21 to 23. Replaced lots of gauges to make sure all were working, to many to list.
    My son and i are very excited to get it on the water, its to bad we live in Michigan and there's going to be ice on the water. Best we are going to be able to do is half of a 55 gallon plastic drum to test it with in the garage. Wife is going to love all that smoke in the garage. HaHaHa.
    If i missed anything chime in please.
  15. #89
    Nov 2021
    N. Idaho
    Service manual states: 80 lb. in. Reed cage bolts/ intake bolts 105 lb. in. I use a very small amount of blue thread lock on anything that can run through the motor.
    I usually do it by feel except rod bolts and head bolts.
    Recommend you watch your water pressure like a hawk when you put it in the lake. After raising your motor you might have to block off you upper water intakes or run scoops.
  16. #90
    Nov 2021
    N. Idaho
    Reed valve to block states 25lb. in.
    I hope the pound foot police don't see this post!
  1. Heads identification (mercury 200 black max)
    By BigChief in forum Technical Discussion
    Last Post: 02-15-2018, 04:59 AM
  2. Need some Mercury v6 Identification help
    By gotboostedvr6 in forum Technical Discussion
    Last Post: 08-25-2015, 08:46 PM
  3. Black Max 200 Serial Number identification
    By maineidyl in forum Technical Discussion
    Last Post: 02-25-2014, 05:45 PM
  4. Mercury Tech: Mercury V6 Identification
    By jmadisonbiii in forum Technical Discussion
    Last Post: 05-29-2012, 02:50 PM
  5. 280 wiring Identification Red & Black wire On Starboard Side
    By rsjc in forum Technical Discussion
    Last Post: 02-20-2011, 01:56 PM
