Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 46 to 60 of 99
  1. #46
    Sep 2017
    Ashland city tn
    Bleed lines should b in stock locations. Find some wh22s and Carson or dukas (spell?)reeds (Jay Smith) , and as others said, no black boxes , set timing manually
  2. Thanks SJD1974 thanked for this post
  3. #47
    Nov 2021
    Holland,Michigan
    What about these in link from here?
    https://www.screamandfly.com/showthr...ntake-from-2-4
    Have been offered these from MrG
    5000 RPM
    Three stage carbs with adjustable idle Circuits you can adjust while in gear nice and clean ported manifold keeps fuel mixed improves flow by 35%
    Any thoughts about these options?
  4. #48
    Nov 2021
    Holland,Michigan
    5000 RPM
  5. #49
    Sep 2017
    Ashland city tn
    Quote Originally Posted by SJD1974 View Post
    5000 RPM
    I mean they r good carbs but in my experience they just don't run as good as a set of wh carbs imo I've tried all those other carbs and I'm just a fan of wh carb power. I'd go for wh22s. Wh31s. They have a great idle and hole shot they r pretty easy to find here. Post in the parts wanted section. This is just my opinion take it for what it's worth. Some mite disagree
  6. Thanks SJD1974 thanked for this post
  7. #50
    Nov 2021
    Holland,Michigan
    Thank you, I will look. Where would I look to see what mine are? I plan on replacing the reed's with ccm reeds are the carb stuffers by ccm helpful? Thanks for your help. I'm just full of questions!
  8. #51
    Houston, TX
    Hey Merc, that add says they are WH22s.
  9. #52
    Houston, TX
    Sjd, I would do the reeds. Stuffers if you wish. New switch boxes. Yank the black boxes and oil injection. Then play with setup on your boat. Engine height, good prop, etc. you can spend as much or as little as you want to and end up with a great motor. There is a lot of performance in proper set up regarding engine height and props and that type of thing. I would do the basics on your motor and get it running great and reliable and put the rest of my effort elsewhere.
  10. Thanks SJD1974 thanked for this post
    Likes SJD1974 liked this post
  11. #53
    where in michigan are you?
  12. #54
    Nov 2021
    Holland,Michigan
    Holland area.
  13. #55
    Nov 2021
    Holland,Michigan
    I have a new unknown. What carbs do i have. Check out the pics please. Anyone have the answer. I know i'm a real pain in the A.. as my wife would say
ID:	498633Click image for larger version.
ID:	498634Click image for larger version.
ID:	498635Click image for larger version.
ID:	498636Click image for larger version.
ID:	498637Click image for larger version.
ID:	498638Click image for larger version.
  14. #56
    Nov 2021
    Holland,Michigan
    The jets were for the front 2 were .078 and the top one on the side was a .048 and the one down in the bowl was .080. All on the starboard side.
    1988 Bass Tracker 1800FS Tournament W/ Mercury 150 BlackMax 2.0
    With a need for speed!!
  15. #57
    Jan 2020
    Pinole, Ca
    WH 40s
    Theres nothin wrong with those carbs, run them.
    Most people see the biggest performance upgrade on the intake side of that engine by going from vertical reed front (what you have now) to a horizontal reed front. That combined with fiberglass reeds and reed stuffers will get that bass boat flyin out of the hole.
    There's no point (in my mind) in spending money on other carbs until you go to a horizontal reed front. And don't go 7 petal, the 5 petal horizontal reed setup is what 2.0Ls like.
  16. #58
    Nov 2021
    Holland,Michigan
    Are those jet sizes good to start with? After we purchase fiberglass reeds for the vertical front can those be transferred to a horizontal reed front later if we can find one and do we have to make any other modification to put horizontal on?
  17. #59
    Nov 2021
    Holland,Michigan
    I will start looking for horizontal then, one thing at a time. Will the horizontal work ok with the carbs i have now till i can afford different carbs?
  18. #60
    Nov 2021
    Holland,Michigan
    When adding stuffers, do I need to change anything else with compression going up, such as running premium gas which I already do?
  1. Heads identification (mercury 200 black max)
    By BigChief in forum Technical Discussion
    Last Post: 02-15-2018, 04:59 AM
  2. Need some Mercury v6 Identification help
    By gotboostedvr6 in forum Technical Discussion
    Last Post: 08-25-2015, 08:46 PM
  3. Black Max 200 Serial Number identification
    By maineidyl in forum Technical Discussion
    Last Post: 02-25-2014, 05:45 PM
  4. Mercury Tech: Mercury V6 Identification
    By jmadisonbiii in forum Technical Discussion
    Last Post: 05-29-2012, 02:50 PM
  5. 280 wiring Identification Red & Black wire On Starboard Side
    By rsjc in forum Technical Discussion
    Last Post: 02-20-2011, 01:56 PM
