Page 3 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 31 to 45 of 99
  1. #31
    TX......somewhere?
    its a 16.. 40's won't fit under a clam shell.. they made lotsa red ones..... just as many as drab green..... they even made a "cast" black 16 that looked like a skinny 40!
  2. Likes rgsauger liked this post
  3. #32
    Houston, TX
    Yep, it’s a 16 amp. Single voltage reg. Simple and works. If you have a problem with not being able to keep everything charged, you can always upgrade to a 40 amp at a later date
    ball joints are fun. Or not... sure gotta have the right press tools or otherwise you’re just peeing in a box fan. Good luck!
    if possible, jump your motor up one or two sets of holes and see how she does. Watch your water pressure. There are some half measures that work such as scoops and plugging the top on or two sets of intake holes.
  4. #33
    Nov 2021
    Holland,Michigan
    Thanks for everyone's help. Going to start the reel fun today. Going to remove all the unneeded items from the motor today and move it up. Also have some nice new gauges to put in. Have water temp gauge i am going to put in, just have to find the best place to put sender. This is the fun i like to have!!!!
  5. #34
    Nov 2021
    Holland,Michigan
ID:	497585Click image for larger version.
    So the tan, purple and green wires in that order left to right in the picture. These wires from the box that are connected to the oil injection pump and the reservoir that was on top of the motor do they get removed as well? These would be the ones in the loom. Please and thank you.
  6. #35
    Nov 2021
    Holland,Michigan
    Also can the idle speed control assembly just be removed or do i have to adjust the timing?
  7. #36
    Nov 2021
    Holland,Michigan
    Finally got the compression test done, just didn't have the time or good weather anyways. Got 115 on #1 and 122 +or- a pound on the other five. Test was done cold, with all plugs removed, jumped starter to turn over engine roughly 6 revs, lubed cylinders with wd40 before testing each cylinder, put some water to the lower to lube water pump just as a precaution.
  8. #37
    Houston, TX
    Your compression is perfect. Once you have it running well, you can also hose it down with sea foam and let it dissolve the carbon from the piston and rings and that one low cylinder might pick up. Anytime you remove boxes or make changes to the ignition components, it’s always best to check the timing. 23° seems pretty safe.
  9. Thanks SJD1974 thanked for this post
  10. #38
    Houston, TX
    Give some strong thought to replacing both switch boxes. With that compression, that motor is probably bone stock and has never been touched. For the sake of reliability and also to find those RPMs that come and go, new switch boxes would probably take care of that. They are $300 for pair from Sierra and you want the ones that are made in Germany. Ohm your stator, too.
  11. #39
    Nov 2021
    Holland,Michigan
    Friend of mine came over and we checked the timing it's currently at 19. I have removed the idle stabilizer and all the wires that are attached to it. The black and white wire that jumps between the two switch boxes is still there. I have also removed the box for the oil injection system and all the wires attached to it. I need to find the horn for the overheat and what sensor is telling it that it's overheating. I installed a water temperature gauge with the sender in the top where the water pressure comes from the water pressure is also connected there and they are both working. I'm going to pull the carbs apart check and make sure the floats aren't the old ones saturated with gas just need to find a gasket kit. Going to also pull the fuel tank flush it and replace all the fuel lines. After all this get it out on the water set the timing where it should be get the motor moved up a hole or two and hopefully we can hit 60. If it still has that up and down speed on us we'll get a couple of switch boxes. If I'm leaving anything out fired at me.
  12. #40
    Nov 2021
    Holland,Michigan
    Hopefully when all this is finished I can get it to run up to temperature most I can get to that right now is 110°
  13. #41
    Nov 2021
    Holland,Michigan
    Ill have to post a picture of the old girl when my son and i are finished with all the improvements. Replaced all the lights on the trailer tonight with LEDs and added a few to give it a little more bling. Looks good
    thanks again to all for the help and suggestions.
  14. Likes rgsauger liked this post
  15. #42
    Sep 2017
    Ashland city tn
    I've got a little 2.0 150 here just like it , great motors last forever , get some good reeds and some 200 carbs and rejet the little motor will gain 3 to 500 rpm up top. Every 150 I get I do this to , and people can't believe the seat of pants difference it makes, I'm sure someone has said it but add little bit of compression on top of what I said. You will b happy with her
  16. Thanks SJD1974 thanked for this post
  17. #43
    Nov 2021
    Holland,Michigan
    Where might I find some 200 carbs and would Chris Carson reed's be ok. What about the stuffers he makes do they help?
  18. #44
    Nov 2021
    Holland,Michigan
    Is rerouting the bleed lines back to the tank worth the time of helping with load up on longer no wakes or idling?
  19. #45
    Nov 2021
    Holland,Michigan
    I do appreciate everyone's help, this will be my son's first Bass boat and he plans On taking it forward with him in his Bass fishing tournaments, he's
    very passionate about it and has been doing really well. Winning a thousand dollars in cash and prizes his first year was good, he's only 15.
  20. Likes Merc 2.5 liked this post
  1. Heads identification (mercury 200 black max)
    By BigChief in forum Technical Discussion
    Last Post: 02-15-2018, 04:59 AM
  2. Need some Mercury v6 Identification help
    By gotboostedvr6 in forum Technical Discussion
    Last Post: 08-25-2015, 08:46 PM
  3. Black Max 200 Serial Number identification
    By maineidyl in forum Technical Discussion
    Last Post: 02-25-2014, 05:45 PM
  4. Mercury Tech: Mercury V6 Identification
    By jmadisonbiii in forum Technical Discussion
    Last Post: 05-29-2012, 02:50 PM
  5. 280 wiring Identification Red & Black wire On Starboard Side
    By rsjc in forum Technical Discussion
    Last Post: 02-20-2011, 01:56 PM
