Page 2 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 16 to 30 of 99
    Nov 2021
    Holland,Michigan
    Iv read that you want your prop 3.5 inchs below pad. Center of prop to pad. Does that sound right? Our whale tail if you want to call it that is just in the water when plained out and trimed. Is that high enough?
  2. #17
    Houston, TX
    Oh boy...engine height...break out the popcorn!
    You want your whale tail above the water when running. It does NOT need to be in the water for drag and also stress on the mid.
    Lets get get the motor reliable and then play with height. Check a post in the bass boat forum similar to your questions when you have a sec.
    Final height is is about setback and hull type. I have 12” of setback and 1” above pad and need another 1/2” up. Do you have a jack plate? Do you have a water pressure gauge yet?
    you will find a bunch of good guys with tons of knowledge who freely share it on a daily basis here.
  3. Thanks SJD1974 thanked for this post
  4. #18
    Nov 2021
    Holland,Michigan
    We do have a working water pressure gauge don't have a Jack plate wish we did out of the budget right now.
  5. #19
    TX......somewhere?
    not a 40.. clamshell is a dead give away.....
  6. #20
    Nov 2021
    Holland,Michigan
    I'm not exactly sure what you mean by not a 40
  7. #21
    Pekin, IL
    You have a 9 or 16 amp stator, not a 40 amp stator.
    Rock
    Team Junk
  8. #22
    Nov 2021
    Holland,Michigan
    That's good to hear it wouldn't be liquid cool then would it
  9. #23
    Nov 2021
    Holland,Michigan
Name:	150 blackmax1.jpg
ID:	497417Click image for larger version.
Name:	150 blackmax.jpg
    Can anyone help me with these numbers as to what they are, please.
  10. #24
    Houston, TX
    Quote Originally Posted by rock View Post
    Rock
    I thought the red ones were 40's...
  11. #25
    Pekin, IL
    Hard for me to see the color. Old and half blind. I have never seen a 40 amp system on a clamshell motor. Doubt it would fit. Also looks to be a voltage regulator on top of motor.
    Rock
    Team Junk
  12. Likes rgsauger liked this post
  13. #26
    Nov 2021
    Holland,Michigan
    I measured my prop to pad today and its 5.5 inches!!!! That's center of prop to pad. This is on the 1988 Bass Tracker 1800FS with my 1988 Mercury 150 black max with a Quick silver laser 2 21 pitch. Feel like if i went up 2 holes i should be able to up a pitch or two. Does that sound right. I had a friend looking at the motor running cold issue i am having, he told me that its getting to much fuel and that could cause it to run cold and i should check the floats. He told me the original floats can absorb the gas over time and get heavy. Where would be a good place to get parts for these older motors? Again thanks for all the previous information.
  14. #27
    Houston, TX
    5 1/2 inches below pad is absolutely buried. Definitely need to come up some. have to keep an eye on your water pressure as you do. In my experience, laser II props suck monkey balls. I have tried them on several boats and they have never run worth a damn. They do not have enough diameter and not enough cup on the blades. Try to borrow a buddys Prop that has more of both. You will know when you are getting close. Pitch is the last thing to work on for your RPMs. I picked up about 7 mph over laser prop just by experimenting with other props.
  15. Likes SJD1974 liked this post
  16. #28
    Houston, TX
    And yes, you can probably end up running on 23 once you raise your motor. Absolutely positively have to watch your water pressure as you do.
  17. #29
    Houston, TX
    When you have a minute, post a better picture from the rear of your motor where the voltage regulator is so that we can see what you have.
  18. #30
    Nov 2021
    Holland,Michigan
ID:	497519Click image for larger version.
ID:	497520Click image for larger version.
ID:	497521Click image for larger version.
ID:	497522Click image for larger version.
ID:	497523Click image for larger version.
ID:	497524Click image for larger version.
ID:	497525Click image for larger version.
    Here are a few. I've been having a grand time replacing the ball joints on my wife's Grand Cherokee. Little sarcastic there. Have no one too borrow a prop from but i will figure somthing out. Will be working on the boat tomorrow.
  1. Heads identification (mercury 200 black max)
    By BigChief in forum Technical Discussion
    Last Post: 02-15-2018, 04:59 AM
  2. Need some Mercury v6 Identification help
    By gotboostedvr6 in forum Technical Discussion
    Last Post: 08-25-2015, 08:46 PM
  3. Black Max 200 Serial Number identification
    By maineidyl in forum Technical Discussion
    Last Post: 02-25-2014, 05:45 PM
  4. Mercury Tech: Mercury V6 Identification
    By jmadisonbiii in forum Technical Discussion
    Last Post: 05-29-2012, 02:50 PM
  5. 280 wiring Identification Red & Black wire On Starboard Side
    By rsjc in forum Technical Discussion
    Last Post: 02-20-2011, 01:56 PM
