Results 1 to 4 of 4
Thread: Powerhead to Adapter Gasket
11-26-2021, 06:17 PM #1Junior Member
- May 2020
- FL
- 13
Hello all, I have a Johnson 1985ish 200 looper. I'm in a small time crunch to get the boat in the water. Anyway I am changing mid section length and need the gasket between the powerhead and adapter/tuner section. Has anyone used just some high temp gasket silicon or something similar?
11-27-2021, 03:35 PM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
No Go.....wait and do it rite..........
11-28-2021, 09:36 PM #36000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 341
- 174
I would definitely not do that. The gasket is pretty thick, not sure RTV would do the trick. In a pinch when I was in a similar situation but the gasket was back-ordered I made my own from a roll of aramid sheet gasket, gasket punches, and an old one as a template. It actually worked fine.
Matt
11-29-2021, 02:45 PM #4Junior Member
- May 2020
- FL
- 13
Thanks for the responses. I thought I would need the gasket sooner but as usual a couple of rusted bolts got in the way. The gasket is supposed to come in today so hopefully its the right one.
Gasket between Taylor Mid and Exhaust Adapter?
By rjdubiel in forum Technical DiscussionReplies: 1Last Post: 08-31-2016, 08:17 PM -
Better than OEM PH to adapter gasket- 2.5 merc
By CircleHook in forum Technical DiscussionReplies: 1Last Post: 04-22-2015, 01:46 PM -
Adapter plate gasket #s
By ActivatedSludge in forum Technical DiscussionReplies: 3Last Post: 11-17-2013, 06:28 PM -
Reuse adapter plate gasket
By ucf_motorcycle in forum Technical DiscussionReplies: 9Last Post: 01-11-2009, 11:01 PM
