Results 1 to 4 of 4
Thread: 2.5 7 pedal front half.
11-26-2021, 02:13 PM #1Junior Member
- Jun 2021
- Cincinnati
- 11
I have a 200 ff block that I am looking to put a 7 pedal front half on. Any help on this swap would be great too.
11-30-2021, 10:23 PM #2Member
- Nov 2018
- lancaster, Pa
- 85
- 11
- 58
- 22
Pretty easy swap. has to be a small being though. the 200's (225's/240's) were small bearing and some of the 260's. later 260's and 280's (not sure about drags) were big bearing, won't fit crank. should bolt right up how the 5 pedal came off. gl finding one!!
Project7 liked this post
12-01-2021, 01:41 PM #3
Recommend removing alignment dowels and remove crank ring wear grooves. This will allow the crank to align the half to block in case of casting/machining differences. (Halves are originally matched to mating blocks so very possible not a perfect fit, but crank dimensions should be the same) and prevent crank ring groove mismatch
Project7, tunnelmike liked this post
09-14-2022, 05:29 PM #4Junior Member
- Jun 2021
- Cincinnati
- 11
not needed now
By bahamatrama in forum Misc. Parts and AccessoriesReplies: 1Last Post: 04-16-2014, 08:12 AM -
4 Pedal Vs 7 Pedal front half?
By 86vintage in forum Technical DiscussionReplies: 10Last Post: 12-22-2006, 10:21 PM
