Results 1 to 15 of 18
    Jan 2020
    Pinole, Ca
    Big bearing freshwater case
    Fishin case...used...good driveshaft nut threads and carrier retainer nut threads. I was gonna build a coned case with it but then realized I already have 4 lowers and don't need another one...its a later one with zincs on the sides.
    $200 plus shipping or you can pick it up in the bay area, California.
ID:	496930Click image for larger version.
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
    Jan 2020
    Pinole, Ca
    Bump...this should be in the lower units section i guess...thats where people put empty housings...
    Jul 2002
    FT WORTH, TEXAS
    If side zincs this would be a 1647 9147C 1 case (check casting number between the two holes in the tail section) and in my .02 worth is the best of merc case to cone good luck with the sale
  4. Likes rjdubiel liked this post
    Jan 2020
    Pinole, Ca
    Its a C not a C1 case. So no zincs on the sides. The zincs you see are from a sportmaster underneath it on my stand.
    For any prospective buyers I can cone this and put the lwp on it for a couple hundred more. And if noone buys it I will be coning it.
    Mar 2004
    Brooklyn Park, MN
    as long as the case has 1647 9147 it is the good case from what I have found (big bearing ratchet case)
    1973 Viper
    1978 Viking
  7. Likes TEXAS20225 liked this post
    Jan 2020
    Pinole, Ca
    Yes, its a 1647-9147 big bearing case. And I have one Land N Sea nose cone left from my stash. The ones that weigh like 1/4 of what the Bob's overbuilt ones weigh...I'll weld that on and putty it up if this isn't sold in a few weeks.
  9. Likes rjdubiel, TEXAS20225 liked this post
    Jul 2002
    FT WORTH, TEXAS
    KEEP IT they are very scarce in my neck of the woods most i run across have major skegg issues, far as i can recollect c cases started showing up on early XRI( note far as i can Recollect )
    Jan 2020
    Pinole, Ca
    I have 3 4 hole CLEs and 2 Coned lowers...I don't really need another...
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by TEXAS20225 View Post
    Can you or anyone here answer a technical question for me? Why did all the cases after 9147-C quit using the oil ladder sleeve around the driveshaft? What exactly did they change in the casting that replaced the sleeve and made it so oil travels upward?
    Did the getting rid of the sleeve do anything for performance other than changing the oiling?
    Jul 2013
    Think it went away when the double bearing driveshaft came into service. The same spiral sleeve would not fit with the double bearing driveshaft.
    Probably realized it wasn’t needed once removed. There’s so much turbulence going on in the gearcase that oil is getting to the upper bearings.
  14. #11
    Jan 2020
    Pinole, Ca
    Nah C1, C2, C3 and C4 are still single bearing but don't have the sleeve.
    Its true none of the double bearing cases ever had it. But the 4 hole CLE cases had it both the narrow passage (fishing guts) and the wide passage (sporty guts). They had the oil sleeve in all the CLEs, even during the production of the sportmasters without it...so why did the fishing cases stop using it beginning with the C1 case?
    Jul 2013
    Like I said probably realized it wasn’t needed to oil the top bearing.
    More then likely used up existing inventory and now it’s NLA.
  16. Likes 25two.stroke liked this post
    Jan 2020
    Pinole, Ca
    It is NLA...
  18. #14
    Jul 2002
    FT WORTH, TEXAS
    they increased the hole size drilled in the case at oiling point to 5/16 ive assembled a ton of CLEs with it missing no adverse affects were noted . ive also ran my on personal Sportys without the double bearing (Till i quit running them all togather)
  19. Likes 25two.stroke, racervboat liked this post
  20. #15
    Jan 2020
    Pinole, Ca
    Ok this case got the nose tacked on, original water pickups closed, and is getting a mild torque tab installed.
    I'll epoxy it all up and prime it, then it will be for sale as an empty coned big bearing case. $750
    If anyone has a big bearing gearset (mercury #43-44104A2) and a propshaft (44-94148) I will consider buying it and building this complete. I have a carrier, driveshaft etc. already.
  21. Likes MrG liked this post
  1. C-1 big bearing case
    By pappa pete in forum Parts Wanted
    Last Post: 08-08-2018, 04:35 PM
  2. 2.5 200 big bearing case
    By Armyvet in forum Parts Wanted
    Last Post: 01-12-2018, 06:59 PM
  3. 200 big bearing case and sportmaster case
    By z520 in forum Lower Units
    Last Post: 07-29-2014, 06:21 AM
