Results 1 to 8 of 8
    Feb 2012
    England
    V8 - Expansion chambers
    Hi - Has anyone done this to create 8 ports for fitting expansion chambers other than this one done by Rude in Sweden.
  2. Likes Capt.Insane-o, Forkin' Crazy liked this post
    Aug 2019
    Palmharbor
    I think he is The only one that tried that . But I question the rigidness of the block being it seems too take out supporting internals That keep it from splitting apart it was a internal web of block
    If you look closely you will see the "gusset" that is provided by the semi-circular cut in the remains of the block.
    The "bolt in exhaust manifold" appears to be .500 or .625 thick. Bolted to the base along the centerline and up the sides to just below the deck. That alone would be enough , but then you have steel tubes forming an X which forms a triangle between them and the base .. LOL It's ain't goin no where ..
  5. Likes Dave Strong liked this post
    Like to see a pic of the intake.
  7. Likes Mark75H liked this post
    I think there is a V8 mounted in a car with expansion chambers
  9. Likes Dave Strong liked this post
  10. #6
  11. Likes Dave Strong, InjectorService liked this post
  12. #7
    charlotte,nc
    I remember John Lentzkow way back when.
    http://web.archive.org/web/200109210...pe_project.htm
    death is certain; life is not
  13. Thanks Mark75H thanked for this post
  14. #8
    Central Florida
    Google "Rudezon" for content on the Evinrude V8 in the Volvo Amazon. The Swedes building it were on facebook under that name. I know they got it driving but don't know how well it worked as a drag car.
    I don't recall seeing details of the intake other than it coming up from underneath and out the front with two large throttle bodies.
  1. Rude 300 with expansion chambers
    By stenmark in forum Technical Discussion
    Last Post: 10-02-2015, 06:59 PM
  2. 8 cylinders, 4 carbs, 2 rotary valves, 4 expansion chambers ... 400 hp
    By Mark75H in forum General Boating Discussion
    Last Post: 07-27-2008, 08:36 PM
  3. omc with expansion chambers
    By mike bryan in forum Outboard and Racing History
    Last Post: 08-25-2004, 11:54 AM
  4. expansion chamber travel
    By mercrazy in forum Technical Discussion
    Last Post: 06-15-2002, 12:39 AM
  5. Piston thermal expansion
    By MadMat in forum Technical Discussion
    Last Post: 02-01-2002, 11:15 AM
