Results 1 to 8 of 8
Thread: V8 - Expansion chambers
11-12-2021, 01:49 AM #1
Capt.Insane-o, Forkin' Crazy liked this post
11-12-2021, 07:33 AM #25000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
I think he is The only one that tried that . But I question the rigidness of the block being it seems too take out supporting internals That keep it from splitting apart it was a internal web of block
11-13-2021, 10:43 AM #3
If you look closely you will see the "gusset" that is provided by the semi-circular cut in the remains of the block.
The "bolt in exhaust manifold" appears to be .500 or .625 thick. Bolted to the base along the centerline and up the sides to just below the deck. That alone would be enough , but then you have steel tubes forming an X which forms a triangle between them and the base .. LOL It's ain't goin no where ..
Dave Strong liked this post
11-13-2021, 12:03 PM #4
Like to see a pic of the intake.
Mark75H liked this post
11-13-2021, 06:21 PM #5
I think there is a V8 mounted in a car with expansion chambers
11-14-2021, 12:16 AM #6
Dave Strong, InjectorService liked this post
11-14-2021, 07:43 AM #7
I remember John Lentzkow way back when.
http://web.archive.org/web/200109210...pe_project.htmdeath is certain; life is not
Mark75H thanked for this post
11-17-2021, 10:27 PM #87000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
Google "Rudezon" for content on the Evinrude V8 in the Volvo Amazon. The Swedes building it were on facebook under that name. I know they got it driving but don't know how well it worked as a drag car.
I don't recall seeing details of the intake other than it coming up from underneath and out the front with two large throttle bodies.
Rude 300 with expansion chambers
By stenmark in forum Technical DiscussionReplies: 53Last Post: 10-02-2015, 06:59 PM -
8 cylinders, 4 carbs, 2 rotary valves, 4 expansion chambers ... 400 hp
By Mark75H in forum General Boating DiscussionReplies: 27Last Post: 07-27-2008, 08:36 PM -
omc with expansion chambers
By mike bryan in forum Outboard and Racing HistoryReplies: 2Last Post: 08-25-2004, 11:54 AM -
expansion chamber travel
By mercrazy in forum Technical DiscussionReplies: 17Last Post: 06-15-2002, 12:39 AM -
Piston thermal expansion
By MadMat in forum Technical DiscussionReplies: 5Last Post: 02-01-2002, 11:15 AM
