Results 1 to 14 of 14
Thread: OMC VRO pump
    May 2001
    Summit,N.J./Lake George,N.Y.
    OMC VRO pump
    I know all to well that the early VRO pumps failed "lean" with no warning until the death rattle was heard and you were dead in the water . I seem to remember that the later year pumps late 90"s into the 2000"s
    failed "rich" with smoke cloud and fouled plugs/a good thing, am I correct or do the later pumps fail lean as well. Thinking of replacing the pump in my 2002 115 while they are still available would rather not mix if I don't have to been running it for 10 summers with no issues.
    Thanks
    Gone*
    Glasspar G3*
    GW Invader*
    Allison SS2000*
    Allison XR 2002*
    Centurion Barefoot Warrior*
    Glastron CSS 16*
    1988 Viper/never rigged or wet*
    1988 Sanger Barefoot V4
    2000 Sea Ray 280SS cruiser
    Wooden 16 Adirondack Guide Boat
    Lowe fishin boat 6hp OMC
    1995 Donzi 22 Classic*
    1996 Donzi 22 Classic*
    Hydstm VooDoo*
    Oct 2018
    Tennessee
    I always eliminated the vro on my omc,s, for the reason you said of failing, it only takes a few seconds of no oil at 7k to do some real damage, I would rather know it is getting the oil myself, just my opinion
    (Rip. Whiteally02) -dad
    Oct 2018
    Tennessee
    Sep 2021
    New Richmond, Ohio
    The early ones we had put to much oil in the later ones have a o ring that goes bad and lets oil into the carbs when not running after a few days later you have trouble starting the motor or it would not start at all carbs would be full of oil they also make a repair kit but its better to replace the vro unit they all have trouble the oil line on the mercs go bad cause no oil to pump and the gear on crank goes bad sometimes dont go 40 to 1 unles you are turning over 6000 rpm will cause rings to stick then you got trouble jim45157
    Dec 2003
    rockford ill.
    I’ve always had good luck with 40:1 idleing to mid range and w.o.t. Using xd50
    Oct 2018
    Tennessee
    Worst case you would foul out a champion plug, I never had any real issues other than that, better then losing a ring, and shoving a piston with broken rod through block
    Sep 2021
    New Richmond, Ohio
    Hi tom its jim45157 i think you would be better off replacing the vro pump if your good at rebuilding things give a kit a try but most tecks install the vro pump thanks jim45157
    7 Post(s)
    I am a VRO fan.
    In my life, had one failure and it over oiled and was covered under warranty.
    I lived in Fla for 9 yrs and bought every blown up V-6 looper I could find and ZERO were caused by failed VRO’s.
    Yrs back, I bought an STV w/a ‘1994 225 looper on it.
    That motor turned 7200 every time out.
    With…….., a functioning VRO.
    Zero issues.
    I owned two different 24’ Sonics, both w/twin V-6 loopers, one pair I bought new, one pair I built from spare parts while inFla.
    Put 100’s of hrs on both sets.
    Other than replacing one wk one on the pair I built, zero issues.
    On my current twin OB 25’ Checkmate project, powered by V-6 loopers, both run VRO’s.
    If you are thrashing on them, the factory manual says to mix 50:1 in the tank for safety.
    I like making it easy to use, low drama, low smoke, and to continue to wave the two stroke flag.
    I even install remote fills for the oil tanks so I don’t have to crawl in the back of the boat, move cushions, vest etc, try not to spill it etc.
    They made a 2 gl tank which I run, and can run 5 - 6 tanks of fuel before adding oil.
    So no extra oil jugs in the bilge.
    W/the latest era carbs, w/the allen screw idle adjuster screws, tuned properly, you can get the motors to idle smoke free once warm.
    I also build/install electric fuel primers so I don’t need to squeeze a primer bulb.
    As close to 4 stroke/EFI ease of use as possible and on a $1500 motor that’s 50 - 100 lbs lighter, per.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  9. Likes David, z1rider, 58Evinrude liked this post
  10. #9
    Oct 2018
    Tennessee
    I guess I owe wanting to remove them to my dad, he was always scared of them cause he blew up a 225 vind. Powered because one failed him at 6500 and blew up before he knew what happened, so he always mixed 1 to 5 and we never had any issues after that
  11. #10
    Jan 2003
    aalsmeer
    Quote Originally Posted by Will hedrick View Post
    In the omc manuals it actually states to premix 1:50 in the tank on top of the VRO for performance boating
  12. #11
    Oct 2018
    Tennessee
    So the extra oil never hurts , he never had the manual, hence why I try to get one whenever I get a new motor
  13. #12
    Dec 2003
    rockford ill.
    I have to admit I never had any problems with vro either/ran it for 5yrs. On my 1989xp 200 but when it comes to mod it’s-to me-nice knowing there’s light fuel pressure waiting on hand to be used and pre-mixed.
  14. #13
    7 Post(s)
    If the VRO takes out the motor, everything is scored and blue.
    Crank, Rod journals sleeves.
    Which Ive never seen.
    If the motor took the top off a piston off, that’s not lack of oil.
    Yes to the extra oiling.
    That was in my 9 page diatribe above ��
  15. Thanks Will hedrick thanked for this post
    Likes 58Evinrude liked this post
  16. #14
    Sep 2021
    New Richmond, Ohio
    It all comes down to one thing do you want to add oil every time you put gas in your boat most people donot want to do that vro has been around a long time the new direct injection can have trouble also since vro and merc put on ther motors i only saw one motor that blew up that was a merc i ran mercury for 21 years only thing that went bad was a oil line not eyeryone on here is in to hi perforance racing most people just like to boat do maintiance and both omc and merc should serve you well jim45157
  1. Trim Pump or Jack Plate Pump Mounting Plates, Solenoids and Harness
    By Onetime in forum Misc. Parts and Accessories
    Last Post: 09-10-2021, 08:35 PM
  2. Replies: 7
    Last Post: 11-26-2013, 08:58 PM
