Results 1 to 15 of 23
11-03-2021, 01:22 PM #1Junior Member
- Jun 2019
- South Louisiana
- 12
- 14
Can this be JB Welded/ Epoxied? Seeking Opinions
1999 Mercury XR6 Carb'd
S/N: 0G825341
Had the #5 piston come apart at WOT and pieces of the piston skirt slammed into the crankcase cover resulting in a quarter sized hole. I'v attached pictures of said hole and piston. Crankshaft suffered no damage thankfully so i am going to rebuild. My biggest obstacle however is this hole in the crankcase cover. Aside from crankcase compression, this area of the crankcase cover does not seem to be a high stress area.
Does a JB Weld or Epoxy type repair seem practical in this situation? Would welding it be better? Any/all opinions are welcome.
- Thanks
11-03-2021, 02:54 PM #2Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3031
- 5318
I’ve TIG welding those before I don’t know how JB weld would last. I’ve seen it done with a wire feed because TIG welding does build heat. You definitely want to heat that area up prior to welding to get any permeated oil out of the metal. If I remember correctly I used a thick piece of copper on the opposite side build everything up and then mill it down, never had a problem.
ProXR6 thanked for this postTEXAS20225 liked this post
11-03-2021, 03:10 PM #3
Seeing as epoxy holds up well covering the oil injection cavity I think you could epoxy that back together ok. Id be sure the backside has loads of contact and fairly thick to give it more strength. As always the bond will only be as good as the prep
11-03-2021, 07:31 PM #46000 RPM
- Feb 2002
- Cudjoe Key FL
- 1,237
- 55
- 300
- 2748
- 3878
That is an easy repair if you find an experienced TIG welder. Build it up, fill hole then grind it smooth.
11-03-2021, 07:59 PM #5
I agree it would be easy to weld but all that heat might not be so easy to keep everything true which leads to bigger problems. I’d epoxy or replace if it were mine.
11-03-2021, 10:10 PM #6
11-04-2021, 06:13 AM #7Supporting Vendor
- 11,838
- 163
- 11
- 795
I’ve had 100% success on the cold side of the 2.5 blocks using A-788 2 part epoxy for over 25 year with zero failures as stated on # 2 oiler cavity….will work on your cold side issues !
Jay @ JSREJay @ JSRE
11-04-2021, 07:31 AM #85000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
I use West Systems epoxy with fabric. Grind around slightly, use tape as a backer. Then over lap the fabric a little on the first side of the hole. Apply the epoxy with a small brush. When it sets, flip it over and repeat. Done many, never had a failure.
11-04-2021, 08:17 AM #9
I've got tubs of Splash Zone , PS-7 , PC-11 , Marine-Tex , tubes of Devcon , JB Weld , Moroso A-B epoxy .. and probably a few more. What none of them will do is show where the cracks radiating from points of impact have spider webbed to .. like heat will. From the looks of this picture , it appears to go from boss to boss and down to the little bomb crater.
Unless you don't mind having fractured parent material under a slab of glue , the best repair is to tap out the broken material .. shape the hole with a carbide burr , make a piece that fits the hole . Weld it in place sand the inside , paint the outside .. done.
Any competent welding shop can do this .
As far as playing Mr. Dairy Queen .. first , there is no where to put an inner backstop , second it's thin material so it will be rows that most have to make thicker as they stack them .. so it will go from about .090 to well .. I've seen it all .
Corn rows also tend to put a lot on heat in a small area , expect the site to shrink as it cools , if you don't tent it , and let it come back slow .. it could crack as well.
I made a big-azz plate that I can bolt 2.5 and 3.0L blocks , front half's and adapter plates to. So no distortion ...
That hole is nothing , I'd be more concerned with getting rid of the crank ring trench's ...
11-04-2021, 08:40 AM #10The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...I'd be more concerned with getting rid of the crank ring trench's...
ProXR6 liked this post
11-04-2021, 09:02 AM #11Junior Member
- Jun 2019
- South Louisiana
- 12
- 14
Thanks for all the suggestions. I do have another used front half on the way that i will attempt to fit with the dowel pins removed. I've got most of my eggs in that basket, but if for some reason i can't make that work, fixing and reusing the original may be my best option, and i feel a lot better about how that hole should be fixed now.
I am also interested in the best way to correct those sealing ring trenches mentioned above....? I'm sure you guys have some clever tricks for that..
11-04-2021, 09:14 AM #12Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
That hole goes to a blind area,,,,, fill it up and go on........Don't change the front have,,,, the sealing wear woun't match.....build it cheep ......quick runn the shipm out of it.......
11-04-2021, 10:10 AM #135000 RPM
- Mar 2015
- DFW
- 665
- 16
- 42
- 366
- 232
when you guys say "cold side" do you mean the front half in general?
11-04-2021, 12:12 PM #14
Part of my graduate study from G.O.B.I.T. (good ole boy institute of technology) taught me that I can't walk into NAPA and buy the specialty tools I needed.
So I built my own ...
Recessed ring brings the old strip of glued belt up to flush diameter.
The width of the drum spans the rib being sized and at least one more at the least, but for most , two ribs as guides.
I have went into motors that had tell-tale signs that they have been gone thru before. Some of them had broken sealing rings. Maybe you can detonate a motor so bad that it will shift the case half and snap the rings .. but I think a 2 stroke would break/ stick the piston first.
So I'm going with maybe a different crank was used ... or the sealing rings were taken off everything cleaned up and put back together with the rings in different locations. Maybe some made it in the blocks "groove" but not the front half's "groove" . Side load them enough and ""bink"" broken rings.
I just know , that if I remove the groove .. lap the crank rings , they all get bedded in at a fresh location of it's likening (less rotating friction).
11-04-2021, 02:44 PM #15Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Yes on that Chazz Show us ya Oring maker..... that one was cool.........Groovy.......
OMC Tech: 1991 Johnson 175 60Deg Eagle Silverstar Leaker, epoxied and holding!
By skimmabird in forum Technical DiscussionReplies: 1Last Post: 10-03-2016, 12:00 AM -
Looper Carburetor Question Epoxied Body?
By outboarddude in forum Technical DiscussionReplies: 1Last Post: 05-16-2013, 09:13 AM -
Mercury Tech: seeking 280 downhousing
By jeffharper in forum Technical DiscussionReplies: 2Last Post: 03-03-2009, 12:07 AM -
Seeking advice
By BOUDREAUX in forum Technical DiscussionReplies: 5Last Post: 03-01-2004, 01:28 AM
