Results 1 to 12 of 12
    Mar 2016
    N/A
    Merc V6 Block bleed line fittings
    Hi,
    Ive got an EE Block 200 Merc V6 which has had the bleed line fittings removed and bunged up on the back of the powerhead. Can these fittings be purchased from mercury or somewhere similar or is it a question of removing some from another block?
    Thanks
  2. Likes seansbaja1982 liked this post
    Pekin, IL
    I may have some if you need em.
    Rock
    Team Junk
    Apr 2017
    Holland,MI
    You can still buy them new
    Yes you can buy them OEM , if Rock is willing to help take him up on his kindness he’s a great guy !!
    Cheers ,
    Jay @ JSRE
    Jay @ JSRE
    Sep 2017
    Ashland city tn
    1 or 2 of em have a check ball in them i believe and others are open , have to be in the right spot also
  7. Likes Aaronhl liked this post
    Jun 2018
    Floating around
    Is there a part number for the two types?
    Jun 2009
    Bristol, Connecticut
    This is what I got in my notes
    Round head push-in fitting 21-426982
    Flat face push-in fitting 21-426231
  10. Thanks LakeFever thanked for this post
    Likes Merc 2.5, LakeFever liked this post
    Jun 2018
    Floating around
    I broke one attempting to remove it before sending the block to the machine shop. I left the rest in there. These are the ones on the sides of the cylinders and are all capped shut from the factory
    Jun 2009
    Are you talking about the elbow fittings?
    Jun 2018
    Floating around
    Ya little 90 brass fittings is that not bleed line fittings?
  14. #11
    Jun 2009
    Yea those should be bleed lines cuz they connect to all the other fittings, I will have to try to find a part number for those 90 degree ones...
    TX......somewhere?
    tha six on tha cylinders are straight thru (no direction) type
  1. 1982 Merc Bridgeport 225 Bleed line fittings
    By MaMikee in forum Technical Discussion
    Last Post: 07-19-2021, 12:21 PM
  2. Replies: 8
    Last Post: 09-24-2010, 02:48 AM
  3. Bleed line fittings
    By vnemous in forum Technical Discussion
    Last Post: 05-30-2007, 07:57 AM
  4. Merc bleed line routing?
    By CDave in forum Technical Discussion
    Last Post: 06-15-2004, 04:12 PM
