Results 1 to 15 of 28
    Apr 2020
    South Carolina
    Milling 5250 Rods
    Can someone let me know the proper amount to mill down on the 5250 wrist pin side in order to make it compatible with a set of top guided pistons?
    Thanks!
    Mar 2004
    Brooklyn Park, MN
    I think .050 off each side to get it to match the bottom. Bottom is .712 and top is .812.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  3. Likes rock liked this post
    Apr 2017
    Holland,MI
    .050 each side. You are better off surface grinding them than milling as milling will cause too much heat.
    Los Angeles Cal.
    .050 each side on top is correct, a Blanchard grinder is the way to go.
  6. Likes ShadowFlier liked this post
    Jul 2002
    FT WORTH, TEXAS
    hmmm still bottom guided on bottom but now cut for top guided pistons
    Los Angeles Cal.
    Quote Originally Posted by TEXAS20225 View Post
    The 5250 Rod that came in 260 motors was considered top guided, 712 on bottom 812 on top. The 818141 rod that came in some drag motors was considered top guided 712 top and bottom. Taking the stock 5250 rod reducing the top to 712 has worked fine for me for 30 years. Have you had a different experience? For some reason I seem to remember I may have one at my shop 5250 rod that was 812 top 812 bottom I will look today.
    Apr 2020
    South Carolina
    280 pistons to be placed on 5250
    Jul 2002
    FT WORTH, TEXAS
    im getting so old i cant recall all the what ifs that have come up through the years there were 260 bottom guide pistons in early days not all 5250 were bottom guide im looking at some chatfieds that were in some 280 they were 5250 so im not sure what were the deals guys so rock on first 5250 were all 812 both ends in Briidgeports all 141 are top guidePS Chatfields are 712 both ends
    Los Angeles Cal.
    A while back I’m certain I saw a 5250 that was 812 on the bottom 812 on the top the bottom cap looked like it had jagged teeth if I recall correctly. I know it’s up in my storage I looked for about half hour today but I just couldn’t find it, I know it’s up there somewhere. With regards to that one I don’t know who was really guiding it.
    Jul 2002
    FT WORTH, TEXAS
    stoker there were 3 versions of the 5250 first ones came on some 2.0 motors a long time ago the 175 mostly they had some features at the cap joint that are not so good i might even have a few left from the 77/80's ##( A while back I’m certain I saw a 5250 that was 812 on the bottom 812 on the top the bottom cap looked like it had jagged teeth if I recall)## sounds like its probably gen one of the 5250,. second versions on the hipo 2.4 they had a slot cut in the they were 812 both ends and the top guided one im sure merc cut the 812 for tguide pistons though i never ran any and the 141 rod with big head bolts were in 260 and 280 i had both of them and i have some chatfields now that are machined from 5250s they are 712 both ends they came out of some 280s i had before i stopped hotrod stuff so lots of people donrt relize how long they been around im 76 next month and have some contact with a lot of merc stuff most folks dont know was around and of course we all know about running bottom guide pistons on top guide rods with the thick washers. there was something though about running top guide pistons on bottom guide rods i just cant get it to the top
    Dec 2001
    HeeeHee...... ya just 76....... ya youngdog rods droop...... the lighter the better big rods make bigger holes............
  14. #12
    Stroker Boy is spot on we modify the 5250 top guided rods to accept the new style pistons ( .812” to .712” top demention ) all the time your better to precise grind these to remove exactly .050” off each side exactly!!! These rods were top guided and OEM in 1991 -1994 fitted in all 260 engines …
    Jay @ JSRE
    Jay @ JSRE
  15. Likes rjdubiel liked this post
  16. #13
    Aug 2020
    Dickson, Tennessee
    I just salvaged a set of 5250's from an 80-81 2.4L with plans on shaving them down for a top guided 2.5L. I havent measured both ends yet but both ends are definitely thicker than the 8141's. Jay, do you cut these for customers?
  17. #14
    Apr 2020
    South Carolina
    Quote Originally Posted by Jay Smith View Post
    Jay @ JSRE
    I have a set of 5 (1 destroyed that came out of a 260) mahle bottom pistons on 5250's. The top and bottoms of those rods are currently .812. You are stating that is still considered top guided, correct?
  18. #15
    ALL 260 were top guided the Mahle had a very thick spacer washers but it was still top guided …
    Jay
    Jay @ JSRE
  19. Likes rjdubiel liked this post
  1. 5250 Rods
    By 6Killer in forum Parts Wanted
    Last Post: 08-14-2013, 06:58 AM
