Results 1 to 4 of 4
Thread: Mercury tech?
    Aug 2020
    Maryville TN
    Mercury tech?
    I'm looking for a Mercury tech/ mechanic to change a 1 piece to a 2 piece exhaust adapter plate on my promax motor, around the Knoxville TN area. Suggestions? Thanks
    Houston, TX
    Welcome to Scream, Rled. It’s not hard to do if you have a cherry picker or hoist. You should have no problem finding a good shop. Plenty of fast stuff in east TN.
    If your Pro Max is of the 225 HP vintage make sure you install that matching vintage 2 piece as the exhaust dump size that leave the block is larger and the same gasket size as 260,280,drag , if the smaller regular 200, 150 HP engines units are fitted in the place of the larger correct 2 piece the engine will over heat due to exhaust leaving will be restricted dramatically . IF you have a 200-150 Pro Max any of the fishing motor 2 piece units will fit …
    Good luck ,
    Jay @ JSRE
    Jay @ JSRE
    Eastern PA
    I think Reynolds Marine is in Harriman, TN. Not sure how close but same state…
  1. MERCURY TECH: mercury black max 150 PROBLEMS
    By magump in forum Technical Discussion
    Last Post: 01-24-2017, 12:54 PM
  2. Mercury Tech: mercury tech or The T-Rex
    By buzmacdowell in forum Technical Discussion
    Last Post: 11-26-2014, 02:28 PM
  3. mercury tech
    By triplethreat0809 in forum Technical Discussion
    Last Post: 06-12-2011, 09:51 PM
  4. Mercury DDT? or tech software
    By Terminal Velocity in forum Technical Discussion
    Last Post: 06-10-2005, 02:52 PM
