Results 1 to 7 of 7
    Nov 2003
    Portsmouth VA
    Hydrostream Viper Hull Blueprinting
    Working the hull on a Viper for a Vintage JP rig. Fill the tunnel in the pad or leave it? I've heard both, and I am sure Pipkorn had a reason for it.
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
    Nov 2003
    Portsmouth VA
    Never mind....
    More info would help. Power used and intended set up would help. I would leave it if it was mine. I did not see your post till now.
    Nov 2003
    Portsmouth VA
    Vintage JP is the old APBA OPC J Production class, v-bottom 100ci stock motor. I will have a 150 Merc inline with XS lower unit for it.
    Also have an old 14' Allison to be set up as a G Production rig (70ci class). Merc 4cyl 85 going on that.
    I would just straighten the bottom so it's the same side to side and def leave the concave pad.It does give some lift. The hot set up for that combo was a 28p small blade chopper with engine set right on the trans top using 15'' mid. Gave a little over 80 MPH, and handled well not needing much pos trim. Battery and fuel on the transom.
  6. Thanks 99fxst99 thanked for this post
    Nov 2003
    Portsmouth VA
    Xstream, thanks for this input. I have cleavers, but no choppers. I will look around for one.
    If you have some cleavers try them. Choppers were what I liked due to lower slip and better planeoff with lots of bowlift with little trim. The original 150XS lower has inlet holes on the bottom of the bullet. They don't like a lot of positive trim, won't allow good water flow into them. Need to run the engine level or very slight pos trim.
  9. Likes crazy horse, wogi liked this post
  1. 1977 Hydrostream Viper - Hull and Trailer ONLY
    By 427Man in forum Hulls up to 20'
    Last Post: 09-12-2016, 08:10 PM
  2. Free Hydrostream Viper Hull (needs restoration)
    By Cynic in forum General Boating Discussion
    Last Post: 10-18-2012, 06:30 AM
  3. blueprinting a hull
    By meat in forum Fiberglass and Composites Discussion
    Last Post: 12-07-2009, 09:25 PM
  4. Blueprinting hull
    By HyperFlow in forum Technical Discussion
    Last Post: 08-18-2009, 09:19 AM
  5. Hull Blueprinting
    By Chris Gerber in forum General Boating Discussion
    Last Post: 09-12-2008, 11:07 AM
