Results 1 to 5 of 5
Thread: 1985 120 Looper vs 140
10-24-2021, 04:50 AM #1
I am trying to determine what the differences might be between a 1985 120 Looper and a 140. Only thing I see in the parts catalog are the carbs being different. Am I missing anything else?
10-24-2021, 07:20 AM #2Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Yes I think the 1.8 120 has smaller inlets and carbs, then they were all the same on 2.0 versions and it was the reeds and inlets only
Yours are 5 over 5, get 140 inlets and add the reeds common to 140 all v6 and most v8's
EDIT sorry, in 85 the 140 had shims under reed stops and same inlet, later went 5 over 5 with different inlet.
I would pull yours to check and fit some new ccm reeds to suit what you are doing with it.Last edited by powerabout; 10-24-2021 at 09:08 PM.
10-24-2021, 04:52 PM #35000 RPM
- Aug 2019
- Palmharbor
- 558
- 20
- 58
- 150
Put the 120 heads on the 140 225 carbs jets 76 mains
10-24-2021, 05:26 PM #4
Per the BRP website, its as a i suspected and is the same as the 200/225 V-6 loopers.
Carbs only.
http://epc.brp.com/Index.aspx?lang=E&s1=835d6a9e-44e1-4c60-8458-6efc600a68a3I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
10-25-2021, 08:19 PM #5
Great feedback. Thanks all.
OMC Tech: gear ratio 1985 120/140 looper?
By suzukidave in forum Technical DiscussionReplies: 4Last Post: 10-05-2013, 12:22 PM -
1985 120 looper timing
By barnes181 in forum Technical DiscussionReplies: 7Last Post: 06-04-2007, 09:42 PM -
1985 v4 looper jetting
By oldschoolltv in forum Technical DiscussionReplies: 0Last Post: 04-15-2004, 10:55 AM -
1985 140 Looper Timing
By HotRude in forum Technical DiscussionReplies: 0Last Post: 03-26-2004, 11:48 AM
