Results 1 to 5 of 5
    Corinth, NY
    1985 120 Looper vs 140
    I am trying to determine what the differences might be between a 1985 120 Looper and a 140. Only thing I see in the parts catalog are the carbs being different. Am I missing anything else?
    5 Post(s)
    Quote Originally Posted by LSaupe View Post
    Yes I think the 1.8 120 has smaller inlets and carbs, then they were all the same on 2.0 versions and it was the reeds and inlets only
    Yours are 5 over 5, get 140 inlets and add the reeds common to 140 all v6 and most v8's
    EDIT sorry, in 85 the 140 had shims under reed stops and same inlet, later went 5 over 5 with different inlet.
    I would pull yours to check and fit some new ccm reeds to suit what you are doing with it.
    Aug 2019
    Palmharbor
    Put the 120 heads on the 140 225 carbs jets 76 mains
    Per the BRP website, its as a i suspected and is the same as the 200/225 V-6 loopers.
    Carbs only.
    http://epc.brp.com/Index.aspx?lang=E&s1=835d6a9e-44e1-4c60-8458-6efc600a68a3
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
    Corinth, NY
    Great feedback. Thanks all.
  1. OMC Tech: gear ratio 1985 120/140 looper?
    By suzukidave in forum Technical Discussion
    Last Post: 10-05-2013, 12:22 PM
  2. 1985 120 looper timing
    By barnes181 in forum Technical Discussion
    Last Post: 06-04-2007, 09:42 PM
  3. 1985 v4 looper jetting
    By oldschoolltv in forum Technical Discussion
    Last Post: 04-15-2004, 10:55 AM
  4. 1985 140 Looper Timing
    By HotRude in forum Technical Discussion
    Last Post: 03-26-2004, 11:48 AM
