Results 1 to 15 of 15
    Jul 2009
    Maine
    Bow eye pulled through
    I just picked up an Action 17, and while Frank Molé was towing it up to ME from MO the bow eye pulled through. He got it locked down and made the delivery without further incident. Today I got up underneath the bow....... its super tight and there's no way I can reach the nuts, plus there was too much damage from pull through. I ended up cutting the eye off with a 4.5" grinder and am trying to figure out how to effect a repair. Besides cutting a hole in the deck, I'm at a loss. Anyone have a magic bullet for me?
    Rich E.
    17' Action Marine/2.5 Pro Max 200
    "Badges.........We don't need no stinkin' badges........"
    Can you go down through the hole for the bow light... I tightened the one on my Checkmate that way.
    Edit: different thought.
  3. Thanks Old_Skool thanked for this post
    Jul 2009
    Maine
    I thought about that and will try tomorrow. Of course I need to order a new eye, but I really need to see what is going on inside the hull. I'll see what the bow light gives me for access and go from there.
    Rich E.
    Jun 2018
    Floating around
    Might have to enlist a tiny helper or cut a hole in the deck, do the repair, then patch the deck and gel/cut/buff
    Jul 2005
    AZ
    Just be careful when placing the ad for help.. wording is everything.
    '84 Checkmate Convincor
  7. Thanks Old_Skool thanked for this post
    Likes Old_Skool, sonicss33, rgsauger liked this post
    Jul 2009
    Maine
    Lmfao!!
    Rich E.
    Dec 2001
    I was towing my Vector and took a curve too fast and the bow eye snapped.....rusted out. Got a new stainless U bolt type and streached out.......long extension and socket.
    Jun 2018
    Floating around
    I couldn’t reach the one on my vking. The hull im restoring im going to install it before I put the cap back on. I’ll have to gel and cut/buff the bow eye area first. Pita
    Nov 2020
    New Zealand
    For a Bow eye to pull through there must be some serious issues that need to be addressed in the block that anchors the eye.
    The Bow eye might be the Canary in the coal mine.
  12. Thanks Old_Skool thanked for this post
    Likes LakeFever, sonicss33, Old_Skool liked this post
    Jul 2009
    Maine
    Quote Originally Posted by NZ Sidewinder View Post
    It really didn't pull through...... but something definitely went wrong inside so that it pulled out at least 1.5". I had to cut it off and push the now, studs/washers/nuts, up into the bow cavity where I could retrieve them.
    Removing the bow light revealed a 0.5" hole for wires to pass through so that access point is a no go. Looks like I'll be getting out the 4" hole saw and opening up this can of worms. Ugh!
    Rich E.
  14. #11
    Jul 2012
    So Cal
    Cut the hole in the bottom. Determine if you can get it with just your wrist inside or your arm from the elbow. Glass the inside then replace the plug. Fill and feather back as needed. No blend or repair on the deck. That’s how I did it and have seen tooling shops use this method also.
  15. Thanks Old_Skool thanked for this post
    Likes Old_Skool liked this post
  16. #12
    Jun 2018
    Floating around
    Be sure to check the core/stringers/transom out too. As above the canary in the coal mine is a real concern
  17. Likes sonicss33 liked this post
  18. #13
    Jul 2009
    Maine
    Quote Originally Posted by cool_change View Post
    That's an even better idea! Thanks!! I'm fine with the glasswork...... its the paint that I'm not really experienced with, especially blending. At least the hull is black.
    Rich E.
  19. #14
    Jul 2009
    Maine
    The boat is structurally sound. It was rebuilt by AFR with Coosa and Michigan board composites back in '09. I suspect the bow eye block was overlooked when the boat was rebuilt. AFR didn't split the hull/deck when they did the work, but they did glass them together. I'll post up the rebuild thread later today when I get back home.
    Rich E.
  20. Likes LakeFever liked this post
  21. #15
    Jul 2009
    Maine
    Rich E.
  1. What is this?? Pulled Powerhead
    By Radiant in forum Technical Discussion
    Last Post: 07-14-2019, 10:04 AM
  2. Getting pulled over
    By wired247 in forum The Scream And Fly Lounge
    Last Post: 04-08-2015, 08:27 PM
  3. Why was my post pulled about won & done ?
    By 1 Tuff 69 in forum Posting Questions and Suggestions
    Last Post: 11-17-2013, 06:37 PM
  4. You know why I pulled you over sir?
    By Capt.Insane-o in forum General Boating Discussion
    Last Post: 07-03-2007, 09:51 AM
  5. Anyone ever get pulled over for being to loud?
    By imq707s in forum General Boating Discussion
    Last Post: 05-06-2004, 07:33 PM
