Results 1 to 15 of 22
Thread: 260 Rings$$$
10-22-2021, 08:52 AM #1
260 Rings$$$
I am getting ready to freshen up my 260 and looked into getting new rings for it. The last time I bought them they were around 400.00
This time they are upwards of 600.00!!! WTH....about fell on the floor!
I contacted an engine builder about possibly getting a discount on the TiN rings. He said he doesn't use those any longer and now uses chromoly black oxide coated rings
in nicasil bores. I thought I would get other peoples thoughts on using those rings. I trust the guy but have never heard of this done. They are much cheaper....Last edited by Flatlander; 10-23-2021 at 09:31 AM.
10-23-2021, 09:32 AM #2
no one has heard of using these rings?
10-23-2021, 04:22 PM #3
Years ago that’s all Gene Treichel used when building nikisel motors . Who is your engine builder ? Hf…
Michael J Giesler liked this post
10-23-2021, 05:13 PM #4Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Ya be lucky to get anything..........
10-23-2021, 05:39 PM #5
I usually do all my own motor work...I was just looking for a better price on gold rings and that is when I heard about the black oxide coated rings. I don't want to say who I heard this from...don't want to cause a pissing match. I never had good luck with Gene, so I'm not sure that helps my decision.
10-23-2021, 06:40 PM #65000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
John Marles. Will take care of you.
10-24-2021, 01:37 PM #7
10-26-2021, 08:52 AM #85000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
Yes.. Been in there 2 years. They Work Just Fine
10-26-2021, 10:50 AM #9
260's originally came with moly rings, TiN rings came out in later 90's to address complaints of early ring replacement. Moly rings seat quicker are easier on cyl plating but do not last quite as long as gold rings.
10-26-2021, 11:49 AM #10
Thank You guys! I figured they would be ok to use...but of course there had to be a downside to them. I was told they would go 100 hours, not bad. My current rings have 120 on them and still have some life left.
The big question?? Merc rings= $600.00 or Black Oxide rings $200
Mrzip, do you know how many hours are on the rings in your motor?
10-26-2021, 02:25 PM #115000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
Quite a few... It's a fishing motor.. I checked compression other day.. No Problems.
10-26-2021, 03:19 PM #12Member
- Apr 2020
- South Carolina
- 85
[QUOTE=Flatlander;3314427]Thank You guys! I figured they would be ok to use...but of course there had to be a downside to them. I was told they would go 100 hours, not bad. My current rings have 120 on them and still have some life left.
Who sells these black oxide rings? Any adverse affects to nicasil?
10-26-2021, 04:19 PM #13Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3030
- 5316
Are black oxide rings actually black?
10-26-2021, 04:29 PM #14
Yes , they are black. Gene gave me the merc number to order and use but I can't find the part number we used then .I do remember I had to order 6 because they came 2 per pack. hf...
10-26-2021, 04:49 PM #15Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3030
- 5316
Only thing I’ve been told on the 260 that I’ve used, is chrome with titanium nitrate coating. I never heard of the inexpensive black rings. Are the black rings good for super high rpm motors?
Mercury Tech: 280 ros rings
By 1750Bullet in forum Technical DiscussionReplies: 2Last Post: 04-11-2012, 09:35 PM -
rings?
By tlwjkw in forum Technical DiscussionReplies: 7Last Post: 03-24-2012, 06:18 PM -
260 rings can i use chrome rings
By jgiroux in forum Technical DiscussionReplies: 2Last Post: 07-02-2009, 09:54 AM -
good rings - bad rings
By roadkill636 in forum Technical DiscussionReplies: 14Last Post: 04-02-2008, 05:25 PM -
piston rings & crank sealing rings
By TB21 in forum Technical DiscussionReplies: 13Last Post: 12-19-2001, 08:49 PM
