Results 16 to 26 of 26
Thread: 86 21ft Laser with OMC V6
06-17-2022, 03:10 PM #16
$2700.
06-20-2022, 12:20 PM #17
Yesterday I unplugged the old trim motor from the harness and plugged the new one in to check that it and the switches and relays are working properly before performing the more significant work needed to actually replace the trim motor. The new motor ran fine. I plugged the old one back in and hit the switch and it ran. I ran the motor all the way up to full tilt, and all the way down to bottom trim from all 3 sets of switches and it worked fine. I'm scratching my head somewhat, but it appears that it may have been just a bad connection at the harness.
07-11-2022, 11:15 AM #18
Make an offer ...
08-02-2022, 03:26 PM #19
The more I review my trim issue symptoms, the more I'm leaning towards it being the relays and not the pump motor. They're pretty inexpensive and should be pretty easy to replace, so I just ordered a new set.
10-21-2022, 05:41 PM #20
Still available. The new relays did not resolve the power trim issue.
10-30-2022, 06:42 PM #215000 RPM
- Sep 2008
- charlestown, ri
- 296
- 10
- 37
if you want i can scan and send you the OMC service manual for the trim troubleshooting section. pretty simple with a multimeter.
10-31-2022, 04:39 PM #22
Thanks for the offer. It's a pretty simple setup electrically. A little more poking around to make sure before I consider replacing the pump motor. I've done it on this motor several years ago, and I have the new pump motor. But there's no easy way to get to that 3rd screw holding the old one in. Next spring I guess.
11-13-2022, 01:33 AM #23
Looks like a Venus ? copy ?
11-13-2022, 10:53 AM #24
Not sure, but I have had it mistaken for a Venus more than once. Still for sale. Somebody should grab before it get's snowed in for the winter .
12-26-2022, 08:00 PM #255000 RPM
- Sep 2008
- charlestown, ri
- 296
- 10
- 37
the way to get that last screw is to knock out the big pin on top of the cylinder. I've tried so many times to pretend to be smart and get them out with some strange 1/4'' extensions/universals to no avail. On the 3cyl motors, you can grind down the inner lip of the bracket to reach the 3rd screw without having to pound on a seized pin with no structural issues. boat looks like a great deal GLWS
01-24-2023, 02:27 PM #26
Sold...
Frank Molé, Instigator liked this post
21ft paramount
By Marinecons in forum Hulls larger than 20'Replies: 0Last Post: 01-13-2020, 01:40 PM -
Laser 3880 completed resto. take a look if you like laser
By chinewalker27 in forum Props, Setup, and RiggingReplies: 6Last Post: 03-18-2013, 09:03 PM -
Laser boat..... Which should i go with.....on my Laser fish and play 19 'ter....
By chinewalker27 in forum General Boating DiscussionReplies: 2Last Post: 06-09-2012, 12:59 PM -
1993 Laser 21ft, question?
By Laserll in forum General Boating DiscussionReplies: 9Last Post: 08-18-2001, 01:39 PM
