Results 16 to 27 of 27
Thread: Tilt Tube Bushings
10-21-2021, 08:30 AM #16
Post # 10 is still applicable :
If yours is unacceptable to you , best thing to do is take it apart and clean it up and look at every single part and piece .. it will tell you what it wants .. not what any of us "think" it needs ..
Repair or replace .
10-21-2021, 09:54 AM #175000 RPM
- Oct 2016
- Northern California
- 144
- 7
Transom brackets are no longer available from Mercury. Do you know how I might get them?
1998 Viper Coral 201
1998 Mercury Promax 300 with Sportmaster
10-21-2021, 07:25 PM #18
Are you sure that's the problem ?
Easy to buy parts you don't need. The brackets don't have much engagement area. The tube will wear them out ... if the nuts are loose and / or there is no grease in the tilt portion of the swivel bracket and the tube is stuck. (rotate in the place of least resistance)
If you look around, you can find individual parts or a complete clamp assembly , pretty reasonably.
Sometimes you can find a complete motor with a good center section and a destroyed powerhead for less than just the brackets .. just gotta beat the bushes ..
I've seen guys shove a screwdriver between the nut and the bracket (1" side of the tube) and use a standard socket on the 7/8ths side , nut. I forget at the moment what size it is .. but I turned down a cheap Harbor Freight socket to fit in the tight spot provided ..
rgsauger, powerabout liked this post
10-21-2021, 08:21 PM #195000 RPM
- Oct 2016
- 144
- 7
No, I am not sure the problem is in the transom bracket, but comparing the up and down movement of the swivel bracket in the starboard transom to what I see in that Yahama video I posted, it sure looks like it might be wallowed transom brackets, especially since there are no bushing there, and you said you've never heard of the tilt tube itself wearing down. What puzzles me is how it sometimes looks like there's no play. The tilt tube can't be stuck in the swivel bracket, otherwise I would see the tube twisting in the transom brackets when tilting up and down, which I don't see. The tilt works very nicely and smoothly.
Makes me wonder if the tilt tube nuts are indeed loose. Trouble is, I don't know how tight the tilt tube nuts are supposed to be. I assume they shouldn't be cranked so much that you pinch or bind the swivel bracket between the two transom brackets, but should the tilt tube nuts be torqued to a certain spec, or do you just make them "tight" by feel?
While I'm there, if I take off the steering ram and remove the tilt tube nuts altogether, I should be able to see if the transom brackets are wallowed by looking at the tilt tube from the side as I tilt up and down, correct? Maybe I should leave the tilt tube nut on the opposite side of where I'm looking in place, so it doesn't move side to side when I tilt up/down, then do the reverse on the other side?
I'm not sure I understand what you're saying here, or why you're saying it. Maybe I haven't look closely enough yet, but I don't remember mine looking like I would have a hard time holding a nut on one side or another, but I will look tomorrow.
Thank you again!Last edited by Basnova; 10-21-2021 at 08:31 PM.
10-21-2021, 09:00 PM #20
I never said the tube doesn't wear. All parts wear, just some quicker than others .. ?
Capt.Insane-o liked this post
10-22-2021, 11:25 AM #215000 RPM
- Oct 2016
- 144
- 7
I figured as much, but since you hadn't heard of one failing, I figure it's not common. Additionally, you've had swivel brackets in for reaming and bushing inserts, so I figure that the tilt tube is stronger than the cast bracket parts, so it's likely a bracket.
That said, I wasn't going to just buy brackets without knowing for sure what's wrong, I was just trying to find out what people are doing these days, since they say NLA on the Merc site.1998 Viper Coral 201
10-23-2021, 06:14 PM #22Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Dave S ....has......many old 1 ram parts......not sure of interchange with newer.........
12-21-2021, 09:15 AM #235000 RPM
- Oct 2016
- 144
- 7
sonicss33 thanked for this post
12-22-2021, 06:47 PM #24Junior Member
- Jul 2011
- huntsville, ontario
- 19
- 16
- 13
12-22-2021, 08:02 PM #255000 RPM
- Oct 2016
- 144
- 7
12-24-2021, 03:12 PM #26
Bass, glad to see ya got it figgert out ..
12-24-2021, 07:52 PM #275000 RPM
- Oct 2016
- 144
- 7
Thank YOU so much for pointing me in the right direction. A shop replaced my jackplate, and apparently put it back together sloppily. I didn't think the tilt tube nuts would have had to be messed with for that, but I guess they must have. But, that's last time I go to that shop! I guess it's like the saying goes, "If you want something done right..."
Merc V6 Swivel Tube bushings
By rs2.2 in forum Technical DiscussionReplies: 1Last Post: 09-22-2021, 12:33 PM -
Tilt Tube and Swivel Tube Bushings?
By 2.5-21 in forum Technical DiscussionReplies: 1Last Post: 09-02-2016, 08:17 PM -
OMC Tech: Easist way to to replace tilt tube bushings on GT-200 Looper?
By imq707s in forum Technical DiscussionReplies: 9Last Post: 07-01-2009, 09:43 PM
