Results 1 to 5 of 5
    Oct 2005
    savannah,ga
    Raker prop to fit a V6 Mercury
    I've got a raker prop with a Mercury hub in it. Problem is after I put the thrust washers,lock washer and the nut on there's not enough room for the lock nut to go all the way down. What do I need to do?
    North Tonawanda, NY
    I had the same issue- and found what was called a "thin elastic jam nut" which was a bit less than half the thickness of the factory prop nut. Worked great...
    Doug
  3. Thanks JBS thanked for this post
    Feb 2020
    Finland Kotka
    v6 viper raker sopii elohopean painelevyyn ja mutterin vaihtoon.
    Dec 2001
    OMC .... HeeHee.... made their props hard to fit on a Merc but Merc easy too fit on their motors. I cut 1/4 inch off the front barrel of OMC raker still short on nut engagement. The prop barrel is too long.Charie Strang.
    7 Post(s)
    Thinner thrust washer.
    Should go one w/a stock hub too.
    Merc wont go on OMC w/o drilling splines out of hub but opposite is true.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  1. Trying to get OMC raker prop to run on mercury?
    By PARKER RABE in forum Technical Discussion
    Last Post: 10-18-2017, 08:49 AM
  2. Will an OMC 22 RAKER PROP WORK ON MY MERCURY 200?????
    Last Post: 09-25-2017, 05:43 PM
  3. 23p Raker prop w/ Mercury hub
    By Slimm in forum Propellers
    Last Post: 03-10-2014, 05:41 PM
  4. OMC Tech: What's the difference Raker & Raker II? Prop
    By decoy033 in forum Technical Discussion
    Last Post: 05-17-2010, 04:30 AM
  5. Mercury Tech: Raker prop on a Mercury
    By captglm in forum Technical Discussion
    Last Post: 04-22-2009, 08:23 PM
