Results 1 to 1 of 1
10-13-2021, 02:41 PM #15000 RPM
- Sep 2008
- charlestown, ri
- 296
- 10
- 37
1991 40hp OMC Johnson / Evinrude rebuilt
Fully rebuilt. Block bored .020" over. Pro Marine coated pistons. New Seals and lower crank bearing replaced (old bearing was just fine, had one lying around the shop anyway). New water pump, gear oil , carbs ultrasonically cleaned. Intake casting burrs taken out. Manual trim. 20" shaft. New plugs and COMPLETE new ignition CDI pack conversion from the old UFI pack setup. 150psi on both. 10 minutes run time. New OEM thermostat. Runs extremely well as it should. starts instantly. asking $1850. Located in Rhode Island.
powerabout liked this post
1988 40hp Johnson OMC Evinrude For sale
By Revenge22 in forum Outboard EnginesReplies: 1Last Post: 08-22-2021, 01:02 AM -
In search of Johnson/Evinrude 1988-1991 v6 exhaust adapter plate
By jwbissett in forum Parts WantedReplies: 0Last Post: 05-26-2021, 07:39 AM -
omc brp johnson evinrude l2-lightning two lower-complete-rebuilt
By anthony714 in forum Lower UnitsReplies: 3Last Post: 10-18-2018, 11:52 AM -
Evinrude/Johnson 2-300 hp Outboard, 1991-94 Manual
By hydroViper235 in forum Technical DiscussionReplies: 2Last Post: 07-17-2009, 08:37 AM
