Results 1 to 15 of 15
Thread: Chimewalk setup
    May 2008
    howard PA
    Chimewalk setup
    So bought new v8 mercury
    Running 2.2 to 1.75 below pad
    With 24 brovo prop. Seems to fall off pad taking abrupt left turn from tork?
    So of If I understand bow too high
    Causing no pad surface to lie on
    So if I would raise motor would bring bow down ??
    Or find prop with less lift
    All so hear this motor will not redline
    With too small of pitch computer control ed
    To limit load and rpms ??
    I need help hear
    Old motor Hammer throttle smooth as silk
    No chime straight.to 74 mph what happened
    Houston, TX
    Hi bud. What kind of boat? Need more info from you. Does it hook when you let off the gas real quick or when does it do it? Mine will hook if I’m up high and then get out of it quickly before trimming down a bump or two.
    May 2008
    howard PA
    Quote Originally Posted by rgsauger View Post
    Yes but while trimming to upper 3/4 is when this happens. It's 21 foot dual console.stratos 701
    6 inch hydraulic bobs jackplate
    Houston, TX
    Any chance that you are trimming too much - too soon? Some hulls need to build up speed before you can feed in more trim.
    Try this... get it rolling pretty well and go to wide-open throttle when you only have about a quarter trim or so. Hold at wide open throttle and bump the trim and give it a minute and then bump it again and give it a minute and bump it again and give it a minute and it will probably tell you how much trim that it wants. With a V-8 sitting on back, and the extra weight, you might not need to trim the boat up as much as you used to.
    Also, you can check the stratos forums over on Bass Boat Central and the setup section. There are some pretty good folks over on that side when it comes to bass boats.
    Houston, TX
    What speed are you running when she hooks? If you over trim and the prop loses bite, it will drop the nose and hook left. Same thing as me getting out of the gas too quickly.
    May 2009
    Ormond Beach, Florida
    Not to be captain obvious but it’s Chine, not Chime……….
    Mark
  7. Thanks Rich Owen, Jimboat thanked for this post
    Likes OnPad liked this post
    May 2008
    howard PA
    Looses control 70. 71 and my evinrude trim stoped at top . Is possible over trim do new mercury v8 have trim limits every one said in hook motor switch can't.trim enough I never have
    I am going out Thursday I'll try bunch of this
  9. #8
    May 2008
    howard PA
    Thanks
  10. #9
    May 2008
    howard PA
    Unhook switch at motor for correction above
  11. #10
    Houston, TX
    Where is your motor height on the new Merc vs your old OMC? You got a water pressure gauge? Low water pickups?
    I would NEVER count on a motor stopping trimming at the place I need it or not going high enough to keep me from hooking. That is something that you have to feel. Have you had the boat for a while? Years? Sounds like you gotta get seat time all over again.
    What does it feel like at 60? 64? 66? 68? Rock solid or greasy?
    Take it easy getting to know this thing. It's a different rig now.
    What motor do you have now?
  12. #11
    Houston, TX
  13. #12
    Houston, TX
    https://basscat.com/forum/groups/bas...my-experience/
    i think you need to come up on motor and less trim. I think you’re over trimming and blowing out.
  14. Likes Jimboat liked this post
  15. #13
    Houston, TX
    yo. you alive?
  16. Likes OnPad liked this post
  17. #14
    Nov 2019
    Shreveport, LA
    I would say less trim and lower the motor. A Torque Master lower unit on that motor should be around 2.5-3.5 inches below pad. If he is blowing out and hooking then he has the motor to high and to much trim. He also needs to watch his water pressure with the motor that high and trimmed all the way out. Just a learning process with the new motor.
  18. #15
    Ontario, Canada
  1. setup 19ft sebold eagle ski tunnel.setback and setup info plz
    By boatdr72653 in forum Props, Setup, and Rigging
    Last Post: 09-06-2015, 09:10 AM
  2. chimewalk??????
    By mountainfreik in forum Technical Discussion
    Last Post: 05-12-2011, 11:52 AM
  3. What setup??
    By baddjonny in forum Props, Setup, and Rigging
    Last Post: 06-20-2010, 08:31 AM
  4. Setup Help please
    By Miniton in forum Props, Setup, and Rigging
    Last Post: 09-08-2009, 05:02 PM
  5. Setup for Valero setup
    By claudius in forum Props, Setup, and Rigging
    Last Post: 05-11-2004, 04:48 AM
