Results 1 to 15 of 24
    The great corn desert of Iowa
    Omc 1979 85hp v4 dry spark plug
    This is about a dry plug on number two cylinder (top left). I bought an old fishing boat last year with a 1979 Johnson 85hp v4. The carbs leaked like crazy and two of the coils showed signs of melting down. I rebuilt the carbs and replaced all the coils, wires and plugs. It ran fine last year. This year it started out running fine but then seemed to lose power. It’s off about 800 rpm’s on wide open throttle. I checked for spark on all cylinders and each was firing. I pulled the carbs and made sure nothing clogged up a jet and found both carbs to be clean. I put new plugs in and ran it again with the same result, down on power. When I pulled the plugs to look at them number two, top left, was completely clean. I thought it might be a water leak but the piston is still black on top. Anybody know what could be causing this?
    1971 Sidewinder 14 SS w Johnson 90 v-4
    1959 Texas Maid Falcon w Mercury Mark 35A
    1981 Sylvan Sportster w Johnson 85 v-4
    2006 Harris pontoon with a Yamaha 90
    1969 Sunfish sailboat
    Sep 2021
    New Richmond, Ohio
    run a compression check on all 4
    Quote Originally Posted by James45157 View Post
    I should have said I did that. Number two is 120. The rest range from 117 to 114. Number two is actually the best.
    NE Louisiana
    So number one is good? They of course share the same carb. You blew through the passage ways the mains go through the bowl and carb body? I have heard of a main that got loose and backed out restricting fuel.
    So you can tell it is missing? Have you pulled the wires off one at a time while running?
  5. Likes H2OPERF liked this post
    Quote Originally Posted by Forkin' Crazy View Post
    yes number one is good. That’s what’s got me really stumped. How is number one wet and running but number 2 is not? (No jokes about aging). I took all the jets out and blew out all the passages, nothing there. I have pulled the wires one at a time and like most v4’s it runs good on three but when I pull another to knock it down to two and it stumbles. I checked the spark and all four jump a 7/16 gap. I also checked the reeds when the carbs were off and none have chips or are broken. For me it’s a real wtf?
  7. Likes Forkin' Crazy liked this post
    MIAMI FLORIDA
    A quick check i often do when your not totally sure what going on with a motor at first is Run it on the hose with the air box cover off and give the throttle a quick rap while looking into each carb and you should be able to see somewhat equal amounts of fuel coming out of the emulsion tubes in each one, its just an easy check for a completely clogged carb without pullin much apart...
  9. Likes Forkin' Crazy liked this post
    Quote Originally Posted by H2OPERF View Post
    Good advice for the future.
    NE Louisiana
    Great idea! Or even better in the lake and have someone run it for you so you can watch.
    That is crazy... Usually when mine were dry, they stuck!
    I figure something must be getting through, at least a little, to keep the cylinder lubricated. But that damn clean, white plug has me baffled.
    Sep 2021
    New Richmond, Ohio
    i had one years ago a guy brough in found a gasket had went bad and was holding a reed open would not run on that cyclinder
  14. #11
    I was afraid it might be something like that. Not looking forward to trying to find out for sure.
    Well it looks like James might be right. Thanks. I took the carbs off again and looked at the reeds with a very bright flash light. This Time didn’t just look for failed or chipped reeds I looked for one that might be slightly open. Yep on the very top row I have one that is open about 1/32. So is there a way to suck it back? I am soaking it in de-carbon spray. Any other methods besides tearing the front off?
  16. #13
    CCM reeds
  17. #14
    James was right. I took off the front of the motor and took out the offending reed block. The one reed was actually more like 1/16 of an inch open. I cleaned up the block, flipped the reeds over and across and put it back together. Fired it up on the hose and now I have a wet number two plug and power from all four cylinders. Thanks again James for pointing me the right direction.
  18. #15
    Now take all the carbs off and remove all the reeds and toss them in the trash... and get a new set
  19. Likes Forkin' Crazy liked this post
  1. Spark plug wires Merc 2.5 HP Blue VS Wizard spark plug wires
    By MERCURY#1 in forum Technical Discussion
    Last Post: 04-02-2020, 07:14 PM
  2. need a 1979 Johnson 75hp Stinger plug n play gear case
    By cosmic12 in forum Parts Wanted
    Last Post: 06-02-2017, 10:23 AM
  3. Mercury Tech: 1979 Mercury 115 - Inline 6 - Spark Advance
    By wcsd106 in forum Technical Discussion
    Last Post: 04-25-2016, 03:55 AM
  4. Wanted: MINT 1978 or 1979 Johnson 85HP cowl
    By FlowMaxx in forum Parts Wanted
    Last Post: 09-19-2014, 03:08 PM
