Results 16 to 24 of 24
Thread: Omc 1979 85hp v4 dry spark plug
10-06-2021, 05:48 PM #165000 RPM
- Feb 2002
- The great corn desert of Iowa
- 298
- 41
- 200
At this point in time it’s just a crap fishing boat and I don’t want to spend that type of money on it right now. Probably will wait till next year and do it.
1971 Sidewinder 14 SS w Johnson 90 v-4
1959 Texas Maid Falcon w Mercury Mark 35A
1981 Sylvan Sportster w Johnson 85 v-4
2006 Harris pontoon with a Yamaha 90
1969 Sunfish sailboat
10-06-2021, 06:13 PM #17Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Maybe I'm wrong but I think you'll be back at the dock sooner than later doing that
Forkin' Crazy liked this post
10-06-2021, 06:30 PM #18Member
- Sep 2021
- New Richmond, Ohio
- 91
- 27
yes what ever you do do not run the motor with old reed that you turned it will break very soon you cannot turn them get new reeds and use lock tite on screws fiber reeds are ok as long as you can run a little rich at idle talk to chris carlson he makes good fiber reeds
10-06-2021, 06:34 PM #19Member
- Sep 2021
- 91
- 27
glad you found the trouble ihave rebuilt at least 50 omc motors over the years the old v4 are like a 350 chevy you can do just about anything to them to make them faster thanks jim45157
10-06-2021, 08:59 PM #205000 RPM
- Feb 2002
- 298
- 41
- 200
Well crud. I’ll look into the CCM’s.
10-07-2021, 08:47 PM #21Junior Member
- Sep 2020
- Long Island NY
- 15
I did ccm reeds in my V4 140 x-flow in July, and I'm pissed it took me this long to do them. Night and day difference. Its only $70 or so, and an afternoons worth of work.
10-08-2021, 07:12 AM #22
I would have a look in that carb bowl for something floating around, a reed may cause some issues but not what you were indicating... a soon as the case pressure starts to build it going to be pushed closed instantly. while causing idle mixture problems you will never see it at power.
10-08-2021, 09:17 AM #23Member
- Sep 2021
- 91
- 27
if the reed is held open by something like a piece of old gasket it will not run on that cylinder the jets in those 85 are very small so do think anything could get past the reed reed will not close if something holding it open
10-08-2021, 04:08 PM #245000 RPM
- Feb 2002
- 298
- 41
- 200
The first thing I did was pull the carbs and check for junk in the bowl or a clogged jet. I could not find anything wrong. When put back on I still had a dry plug. I checked compression next and it was good. Then came checking for spark even though it shouldn’t have anything to do with a dry plug but what the hell. Next came looking for gasket leaks and water intrusion of which both were negative. On James post I looked at the reeds and could see one at the very top was open. After pulling the reed block I pulled the reeds out, cleaned everything out and may have gotten rid of something holding the petal open. All I can say now is that the dry plug is wet.
Spark plug wires Merc 2.5 HP Blue VS Wizard spark plug wires
By MERCURY#1 in forum Technical DiscussionReplies: 12Last Post: 04-02-2020, 07:14 PM -
need a 1979 Johnson 75hp Stinger plug n play gear case
By cosmic12 in forum Parts WantedReplies: 0Last Post: 06-02-2017, 10:23 AM -
Mercury Tech: 1979 Mercury 115 - Inline 6 - Spark Advance
By wcsd106 in forum Technical DiscussionReplies: 3Last Post: 04-25-2016, 03:55 AM -
Wanted: MINT 1978 or 1979 Johnson 85HP cowl
By FlowMaxx in forum Parts WantedReplies: 2Last Post: 09-19-2014, 03:08 PM
