Results 1 to 5 of 5
    Apr 2017
    key largo florida
    32x15.5 Mad Efi 4 Blade
    32x15.5 Mad EFI 4 Blade
    $800
    305-587-3095
    Attached Thumbnails Attached Thumbnails 94133744-546E-4638-A1AC-CDE18331CED5.png
  2. Likes NAVISPEED1 liked this post
    Guys with the 21 skaters that are used to running the 32 pro-et....This is your modern day replacement (you will need to take some diameter out or run your motor higher to turn it up).
  4. Likes webbie73 liked this post
  5. #3
    Sold,
    Thanks Julian-
    Sep 2012
    Quote Originally Posted by JPEROG View Post
    So....got my attention here. I have been looking for a Pro ET that is unobtainium these days. I looked at this prop and saw that it was a 15.5 which is an inch over the ET. So are you saying to buy one of these in a 32 and get it cut down an inch? Or maybe can a 30 work just as well? Are these props available new? Are they a copy of the ET with a bigger diameter? This is for a 21 cat.
    They are not a copy of an ET but do have a very similar blade design. They are a thru hub Vs the Pro-et being an over hub, but they work very well like a Pro-et always has on on heavier hulls. The reason I said you would have to cut it down is simply due to horsepower restrictions "it takes some real torque to put a 15 1/2 dia. four blade into the 6K and up zone without bringing the motor up really high which then pulls blade surface out of the water and lets it rev".
  8. Likes NAVISPEED1 liked this post
  1. Cleaver Prop: 32x15 LH and Rh labbed
    By steven_koenke in forum Propellers
    Last Post: 05-18-2020, 11:24 PM
  2. Replies: 0
    Last Post: 08-21-2017, 07:15 PM
  3. Lost a blade on my 3 blade Mercury Lightning ET and ......
    By Stålproppen in forum Technical Discussion
    Last Post: 07-20-2016, 06:48 PM
  4. Drag 4 32p, Hoss 4 blade 28p, mercury et 3 blade 32p
    By Mercaholic86 in forum Propellers
    Last Post: 05-02-2016, 02:41 PM
