Results 1 to 13 of 13
    Jul 2013
    2.4 Bridgeport Block and Parts
    2.4 Bridgeport Block and front half. Needs welding and a couple sleeve. Definitely repairable.
    Crankshaft. Visual inspection looks good.
    5 rods with pistons. Visual inspection looks good.
    Exhaust divider and cover plate with coils.
    Cylinder heads. Visual inspection looks good, some very minor marks. Useable as is or perfect with light cut.
    Reed plate and air horn. No throttle arm and cable mount.
    Switchbox mounting plate, some wiring, trigger with boss broken.
    Would like to sell as a package.
    $650.00 Shipped USA. Or best reasonable offer.
ID:	493847 Click image for larger version.
ID:	493848 Click image for larger version.
ID:	493849 Click image for larger version.
ID:	493850 Click image for larger version.
ID:	493851 Click image for larger version.
ID:	493853 Click image for larger version.
ID:	493854 Click image for larger version.
ID:	493855 Click image for larger version.
ID:	493857 Click image for larger version.
ID:	493858 Click image for larger version.
ID:	493859 Click image for larger version.
    Sep 2021
    Buffalo, NY
    Still available? If so how much for everything besides block/crank/pistons/rods
    Jul 2013
    Yes still available.
    So you want a price for air horn, Reed plate, cylinder heads, exhaust cover with coils and exhaust divider plate, switch box mounting plate with some wiring and trigger?
    Including front half or not?
    Jan 2020
    Pinole, Ca
    Id be potentially interested in the block, crank and front if the above member wants to take all the rest of the bolt-on stuff.
    Where in California is this stuff located?
    You can call/text 510-418-4911
    Sep 2021
    Buffalo, NY
    Quote Originally Posted by Onetime View Post
    Yes not sure if i would need the front half also to bolt all this to my xr4
    Jul 2013
    Okay
    ctobias1984. For the air horn, Reed plate, cylinder heads, exhaust cover with coils and exhaust divider plate, switch box mounting plate with some wiring and trigger. $250 shipped to your door.
    25two.stroke. For the block front half and crank $350 shipped or meet up somewhere.
    Jul 2013
    ctobias1984,
    Not sure what you’re planning for your build but you kinda need the front half to run the air horn and Reed plate.
    Unless you’re planning something different utilizing the air horn and Reed plate.
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by ctobias1984 View Post
    You would need the front half to bolt it to an xr4 2.4 block. And you will need an ecu, 7 petal reeds and cages, injectors, a fuel rail, fuel pressure regulator, etc.
    Onetime, that price is good with me, but make sure ctobias1984 doesn't need the whole package first. Sounds like he would be better off building this whole block or getting a drop-on bridgeport or 240efi.
    If you decide to sell me the block and front let me know where I would need to meet you.
    Sep 2021
    Buffalo, NY
    Maybe im in over my head but why would i need fuel rail/injectors/ecu on a carbed engine?
    Sep 2021
    Buffalo, NY
    How much for just the heads?
    Jan 2020
    Pinole, Ca
    Best to call one of us on here and sort put what exactly you are tryna do to your xr4. Most of the bolt on stuff you were inquiring about is for efi and won't work on your carb 2.4.
    ... the reed plate, air horn, etc. Won't work with carburetors or your engine block/front. Moreover, the heads here are not likely to give you any performance gains, they are probably identical to what you have on your xr4.
  12. Likes David - WI liked this post
  13. #12
    Aug 2009
    mpls,mn
    PM sent
  14. #13
    Jul 2013
    Sold. Thanks ScreamandFly and Jacob.
  1. 2.4 Bridgeport block/Parts
    By sicknick12 in forum Misc. Parts and Accessories
    Last Post: 01-15-2020, 08:27 AM
  2. 2.5 offshore block 2.0 Bridgeport block
    By MrG in forum Misc. Parts and Accessories
    Last Post: 09-05-2019, 04:03 PM
  3. 2.4L EFI Bridgeport parts: connecting rod roller bearing parts and bolts
    By GamblerSS in forum Misc. Parts and Accessories
    Last Post: 07-01-2019, 08:18 PM
