Results 1 to 2 of 2
    35 Post(s)
    Merc V8 Oil Drain Nipple
    Thought for sure this was a fresh water flush nipple. Turned out to be the oil sump drain nipple. Sits there in a recess in the mid section fairing. Uggggleeee! Anybody know of somebody is making an aftermarket snap-on plastic or rubber piece to cover the nipple and fill in the recess? If there isn't one, there should be!
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by WaterZebra View Post
    Like a rubber plug so it looks like the cowl?
    No one is making a plug for that yet, and you are the first I've heard of that wished there was one! It is interesting that they make a plug for the zinc bolt hole, but not the oil drain.
    It would be cool if someone made one for a 90/115, 150, v6 and v8. They all have the same oil drain but different cowl configurations around that nipple.
  1. Mercury Tech: 2.0L, what is this nipple for
    By pcrussell50 in forum Technical Discussion
    Last Post: 07-02-2014, 08:37 PM
  2. Mercury Tech: Do any of the Merc carb motors have a slight battery drain?
    By Ron V in forum Technical Discussion
    Last Post: 09-22-2013, 08:44 PM
  3. Mercury Tech: Excessive Crankcase drain, on Merc 200 1984
    By Marchettih2o in forum Technical Discussion
    Last Post: 04-13-2009, 09:15 AM
  4. broken nipple
    By stiletto200 in forum Technical Discussion
    Last Post: 09-15-2008, 02:43 PM
